 OK update   I didn’t measure the stroke of the slave cylinder after I extended it I didn’t try that today   But what I did try  Was  with the transfer case in neutral   And the truck running    And I didn’t use the clutch  I tried to put the transmission in gear and it went  ,  so I’m going to guess  and you guys can help me out I’m guessing that the clutch isn’t working like it was put in backwards
Well, that looks like the clutch plate isn't getting released at all.  And I'm not sure why that imprint pattern on the clutch is only on half of it, and not over all of it, as it should apply even pressure to the clutch plate all the way around.
Anyway, I think you need to figure out why it isn't disengaging.
