Temperature reading in truck
1 hour ago, Landon Wingate said:
I have a 2019 trail boss LT and the temp display always reads about 9 or so degrees higher than actual temp.  Is anyone else seeing this and is there a fix?
Mine is always high too.  Yesterday it said 100 degrees lol
+1 always high.  I kind of expect that though since it is relatively close to the engine compartment.  Perhaps a software update could compensate the 5-10F so the display is accurate even if the temp sensor is reading warmer than ambient.
9 minutes ago, Limelight said:
I thought I read in another post that this year they moved the temp sensor to the passenger door mirror.  Not joking...
I read the same thing but I never saw that it was confirmed.
14 hours ago, BlancoSilverado said:
Same, Temp sensor is at the front of the grill. Idk why its always 5-10° above. at least is kinda consistent.
Actually, I believe they've been moved to just under the passenger side mirror. I don't have a pic, but someone posted this in another thread. If you look under that mirror, you'll see a little cut-out and sensor in there.
Mine on my RST is always about 5-10º high as well. Even after I get moving down the road.
Ditto.
Mine's high as well.
So far, 117* has been the highest I've seen. Real world temp on that day was 102*.
That's a huge swing IMO. Especially if the ECU is using that ambient temp info for fuel corrections, or AC regulation duties.
I just figured it was a combination of grille mounted sensor, heat soak off the radiator and a black truck with black grille. ?
I can see GM moving the sensor to the mirror.
Never the less, I'm staying tuned...
