- 0
slight shake or miss on my 2008 6.0 suburban ltz 4wd
Similar Content
- 1 reply
- 1,022 views
- 5 replies
- 3,331 views
- 5 answers
- 3,652 views
- 2 replies
- 2,108 views
- 3 replies
- 3,850 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 14 Members, 1 Anonymous, 1,626 Guests (See full list)
Question
BLACKBIRDMAFIA
I installed a new 6.0 motor with high volume oil pump on my 2008 6.0 LTZ suburban. It has only 500 miles on it at the moment as of 9-5-2019. I installed a new intake, new throttle body, (relearned) new radiator, new plugs, wires, injectors, fuel pump and new heavy duty motor mounts, I have this slight shake at idle and you can feel it in the performance of the truck when driving down the freeway as if something is holding it back, Its not throwing any codes, engine light is not coming on. Had a guy that all he does is reprogram cars and trucks with his computers and when he hooked his high dollar stuff to the truck, the rpm went to zero while it was running and said it was a cam position sensor but when he disconnected it it went back to normal. my regular mechanic hooked up his diagnostic computer (Zuess) right after and it had no codes and we cant find out what is up. Maybe the guys high dollar stuff was messed up. Some guys are saying its the trucks computer but its not showing any codes, it runs fine but it should be absolutely purring like a kitty cat and there should not even be the slightest movement. The guy with the computers said that it has the fuel efficiency program on it that drops to 4 cylinders from 8 to save on fuel, he said the system was on and asked if I wanted it turned off for 250.00. I didn't do it. something is up and its driving me nuts. anybody have an idea at all? the #1 cylinder failed on the original motor and the traction control code came on and said it needed to be serviced. After the motor was replaced it did not come on again and there was no code for it as well. just for some history. Please help
4 answers to this question
