Trailer brake alert?
I’ve gotten the message “service trailer brake system“ several times over the past couple of years it usually just goes away after a time or 2. I was towing a 6 x 12 U-Haul trailer this past week. I must’ve gotten that alert 25 to 30 times in a row it would not stop. Then all the sudden it stopped on my three hour trip.
Coming back yesterday three hours did not get the error message once. Started my truck up this morning to go into work without any trailer hooked up and got the message again.
Anybody here experience this or know what might be causing it?
Truck is a 2015 2500 HD Silverado.
My truck does it every time I hook up a trailer if the truck is running. If the truck is not running when I hook up a trailer, it never does it. Give this a try if you haven't and see if it corrects the issue...
I’ll have to remember that and give it a try next time. Thanks
My 2016 3500 had this same problem.  Service Trailer warning kept coming up while both towing and driving without a trailer.  The dealer was no help as they blamed it on what they thought was corrosion in the 7 pin connector. The tech didn’t know that the contacts are brass and have a brass color lol. There was no corrosion.
i did some research and narrowed the root cause to two possibilities:
GMC Brake Controller Module 23337305
or
Trailer Brake Controller 84108373
I replaced the module, located above the spare tire, and the warning disappeared.  Took fifteen minutes to swap out.
When I told the dealer service writer, they had no idea what a brake controller module was. Oh well. Hope it helps someone here.
or
That’s great info...THANKS!!!
or
I was having the same issue and for me it was the trailer brake controller 84108373. The switch on the dash. Super easy and no issues since.
