Lyons00 Posted August 22, 2019 Share Posted August 22, 2019 HI, I just filled my tires on a 2019 Silverado 1500 LTZ. I made sure they were below the 36 psi what is recommended. I put it in park set the parking brake and left the engine running. For some reason my blinker and horn didn't do anything. Am I missing something? Thanks, Jerry Quote Link to comment Share on other sites More sharing options...
Bikeman Posted August 22, 2019 Share Posted August 22, 2019 Haven't worked for chevy in 10 yrs but used to have to hold the lock and unlock buttons down on the key transmitter to put in tpms learning mode. Otherwise it don't beep. Again ten yrs old info??? Quote Link to comment Share on other sites More sharing options...
mafd2 Posted August 22, 2019 Share Posted August 22, 2019 27 minutes ago, Lyons00 said: HI, I just filled my tires on a 2019 Silverado 1500 LTZ. I made sure they were below the 36 psi what is recommended. I put it in park set the parking brake and left the engine running. For some reason my blinker and horn didn't do anything. Am I missing something? Thanks, Jerry Is it supposed too.? Never heard of that. I thought that was only when learning TPMS sensors using a relearn tool and after rotation. 1 Quote Link to comment Share on other sites More sharing options...
sk Posted August 22, 2019 Share Posted August 22, 2019 (edited) Do you have the new body style? Chevy builds both for 2019: The new one is called "1500" and is supposed to have that feature standard (but the Owner's Manual Page 373 says "if equipped"). I think it only works if your low tire pressure warning light comes on first. The carryover body style is called "1500LD" and doesn't have that feature. Edited August 22, 2019 by sk Quote Link to comment Share on other sites More sharing options...
Lyons00 Posted August 22, 2019 Author Share Posted August 22, 2019 (edited) 22 minutes ago, sk said: Do you have the new body style? Chevy builds both for 2019: The new one is called "1500" and is supposed to have that feature standard (but the Owner's Manual Page 373 says "if equipped"). I think it only works if your low tire pressure warning light comes on first. The carryover body style is called "1500LD" and doesn't have that feature. Hi, Im not sure what mine says, just looked at the sticker and it doesn't say neither of them...thanks. I looked on mychevorlet.com, it says 1500. Edited August 22, 2019 by Lyons00 Quote Link to comment Share on other sites More sharing options...
Ozer Posted August 22, 2019 Share Posted August 22, 2019 The beep is only for when learning the sensors, i doubt it just beeps to let you know youre at 36 psi. I bought the tool from amazon and i can just use that after a tire rotations, so much easier. Quote Link to comment Share on other sites More sharing options...
Booger T Posted August 22, 2019 Share Posted August 22, 2019 Yes it will beep and tail light blinks on the side that you are filling, I don't think it does it unless the low pressure warning is on. This feature has nothing to do with relearning the sensors. Quote Link to comment Share on other sites More sharing options...
Lyons00 Posted August 22, 2019 Author Share Posted August 22, 2019 1 hour ago, Booger T said: Yes it will beep and tail light blinks on the side that you are filling, I don't think it does it unless the low pressure warning is on. This feature has nothing to do with relearning the sensors. Thanks all Quote Link to comment Share on other sites More sharing options...
