2019 Silverado Trail Boss
4 hours ago, Chevygirl62 said:
Purchased our truck 8-17-19. Occasionally when when shut off engine then come back later, insert key it will not start??? BUT IT WILL START REMOTELY??? This has happened about 3 times in 3 days?? What are we doing wrong? I personally think it’s user error.
do you have a custom trailboss or LT trailboss. If you have an actual key then you shouldn't have to press the brake to start the truck. IF its keyless then yes you need to push the brake pedal.
I agree .
6 minutes ago, Chevygirl62 said:
So infuriating, spend almost $50,000 and I have to deal with this nonsense!
Have a house built for lots more money  and deal with the frustrations.
  • Haha 1
12 hours ago, Chevygirl62 said:
LT Trailboss. It does have a key but when problem occurs we can’t even turn the key in the ignition?
Is it because your wheels are turned, and the steering wheel has locked? sometimes that locks out the ignition, if you grab the wheel and turn it straight does that fix the problem?
Edited by aseibel
