85 Chevy overcharging
My 85 chevy has a serious overcharging problem when i am on the highway the gauge reads almost into the red, and the battery is bulged out and leaking juice. What is the first thing I should look for when solving this problem? I have a common style load tester (chrome body with gauge and load switch on the bottom) and I know how to use it to test the battery but am unsure how to check the charging system with it.
:lol: Don't run the truck untill you get the regulator replaced. The battery WILL EXPLODE! The regulator is built into the alternator so it's a quick fix. Rplace the alternator. The battery explosion will cause serious injury and at least bathe your engine in acid.
