Sierra SLE Fog Lights
When I bought my SLE I asked the dealer if they could install fog lights. They said yes but then found out they we not available from the factory and there was a notice to not sell them.
I assumed they were the same as the ones in the SLT, but I recently noticed the shape of the hole is different between the SLE and SLT.
Does anyone have some insight on if or when they will be available? Any aftermarket options?
36 minutes ago, Darren Knight said:
Yeah, those will not fit in the SLE. The opening is slightly different.
This is the only thing I've been able to find online. https://www.ebay.com/itm/2019-New-Generation-Sierra-GM-Fog-Lamp-Light-Kit-84280754-Read-Description-1st-/153220220859
Same exact kit and part number.
Hmm, you're right that it is the same posted part number. However, if you look closely at the shape of the openings on the SLE and SLT. They are different. The lights might be the same, but it looks like the bezel around them is different
You can always order it and if it doesn't fit you have a 30 return policy on the ebay item. Do you have the task lighting RPO U12?
Just order the one from Shop Chevy Parts. It says for U12 task lighting. It's the same kit and cheaper too. Can't go by pics on the site. I ordered tpms sensors with correct p.n. but showed wrong picture. Noticed this on several parts.
Can confirm kit on Shop Chevy will fit SLE. You will have to procure your own hardware to mount the lights however. Not included in the kit and not existing on the truck.
The chrome bezel around them is a separate piece.
  • 1 month later...
Do you have pics of your truck(fog lights).
  • 5 weeks later...
