Rob41 Posted August 7, 2019 Author Share Posted August 7, 2019 Yeah that's a damn good price. I was going to do my own too but I'd rather have someone else compress the strut springs. Quote Link to comment Share on other sites More sharing options...
curly Posted November 1, 2019 Share Posted November 1, 2019 Rob41... Are you still happy with this setup? I just bought a 2019 and a lift is in the very near future and I really like your setup. Quote Link to comment Share on other sites More sharing options...
z1boss Posted November 1, 2019 Share Posted November 1, 2019 On 8/6/2019 at 9:23 PM, Rob41 said: I have seen a lot of level kits and 6" lifts in the forum but haven't seen any T1's with the ReadyLIFT 4" SST yet so here's my RST. I wanted to fit 35" on my T1 but didn't want as much empty space above the tires that a 6" lift has. I read good things about the SST kit in terms of quality which is there, and being a much simpler install that can be reverted back to stock is a plus too. Given that the front diff is narrower and the front axles are much longer than on 18 and below models, this 4" kit should do the trick with It's upper control arms to correct the geometry. Although there wasn't supposed to be any rubbing it was slight but it was there in the front. In the back of the wheel well, I just removed the bracket behind the mud flap and I've got about an inch of clearance now. On the front of the front wheel well it very slightly came into contact with the felt liner. I just drilled a small hole in the liner where it made contact and used zip ties to pull it forward. Lots of extra room now without any trimming at all. Also, the space between the back of the wheels and the brake caliper rib there is almost an inch of space. This it what I've installed so far: 1. ReadyLIFT 4" SST lift kit 2. Fuel Vandal 20x9+1 3. Nitto Ridge Grapplers 35.12 x 11.77 (295/65R20) 4. Gatortrax retractable tonneau 5. OEM Wheelhouse liners 6. Removed "Silverado" from fender and added Black and Chrome Z71 7. Installed quality Stubby antenna I think I'm part of a small group of people here that drives on a dirt road daily so the truck insn't clean in the pics. That looks fantastic! I'll be lifting my Trail Boss another 2 inches with an SST lift kit soon and after seeing your truck I'm even more excited! Quote Link to comment Share on other sites More sharing options...
Dunn Posted November 3, 2019 Share Posted November 3, 2019 (edited) very nice, cant stand wheels bulging out of wheel wells and makes no sense, also I like sidewall on 4x4 vehicle. low profile off road tires is another that makes no sense......what suspension are you running? to me getting excellent struts and shocks are most important.....I wont go that high cuz I have to work out of back of mine daily but love how proportionate everything looks on your truck, nothing looks odd or awkward Edited November 3, 2019 by Dunn Quote Link to comment Share on other sites More sharing options...
Georgiagator Posted November 5, 2019 Share Posted November 5, 2019 Went with a zone 4 inch and 35x12.50 on 20x9 with +18 offset zero rubbing, zero trimming 5 Quote Link to comment Share on other sites More sharing options...
dean flocas Posted November 6, 2019 Share Posted November 6, 2019 I'm also looking at a 4" lift because i want to slap some 35s on. What I am concerned about is the gearing. I have an LT and my gearing is 3.23. What gearing do you have in your truck and do you feel a big loss in power with the 35s? Quote Link to comment Share on other sites More sharing options...
maka1500 Posted November 6, 2019 Share Posted November 6, 2019 Nice setup!!! Quote Link to comment Share on other sites More sharing options...
SatinSilvy Posted November 7, 2019 Share Posted November 7, 2019 Just got my SST Kit today, now I gotta wait till my buddy gets back from vacation so we can install it at the shop. #hurryupandwait Quote Link to comment Share on other sites More sharing options...
dean flocas Posted November 7, 2019 Share Posted November 7, 2019 On 11/5/2019 at 1:57 AM, Georgiagator said: Went with a zone 4 inch and 35x12.50 on 20x9 with +18 offset zero rubbing, zero trimming What kind of wheels are those? they are pretty sweet! Quote Link to comment Share on other sites More sharing options...
SatinSilvy Posted November 8, 2019 Share Posted November 8, 2019 For those of you who installed the SST Kit, did you upgrade the rear shocks? If so what brand did you go with? I’m not a huge fan of using the shock extensions. Quote Link to comment Share on other sites More sharing options...
SatinSilvy Posted November 11, 2019 Share Posted November 11, 2019 On 8/6/2019 at 9:23 PM, Rob41 said: I have seen a lot of level kits and 6" lifts in the forum but haven't seen any T1's with the ReadyLIFT 4" SST yet so here's my RST. I wanted to fit 35" on my T1 but didn't want as much empty space above the tires that a 6" lift has. I read good things about the SST kit in terms of quality which is there, and being a much simpler install that can be reverted back to stock is a plus too. Given that the front diff is narrower and the front axles are much longer than on 18 and below models, this 4" kit should do the trick with It's upper control arms to correct the geometry. Although there wasn't supposed to be any rubbing it was slight but it was there in the front. In the back of the wheel well, I just removed the bracket behind the mud flap and I've got about an inch of clearance now. On the front of the front wheel well it very slightly came into contact with the felt liner. I just drilled a small hole in the liner where it made contact and used zip ties to pull it forward. Lots of extra room now without any trimming at all. Also, the space between the back of the wheels and the brake caliper rib there is almost an inch of space. This it what I've installed so far: 1. ReadyLIFT 4" SST lift kit 2. Fuel Vandal 20x9+1 3. Nitto Ridge Grapplers 35.12 x 11.77 (295/65R20) 4. Gatortrax retractable tonneau 5. OEM Wheelhouse liners 6. Removed "Silverado" from fender and added Black and Chrome Z71 7. Installed quality Stubby antenna I think I'm part of a small group of people here that drives on a dirt road daily so the truck insn't clean in the pics. Any issues using the shock extenders? Or did you upgrade your rear shocks? Quote Link to comment Share on other sites More sharing options...
Shoguns80 Posted November 11, 2019 Share Posted November 11, 2019 (edited) just got my 4" Readylift installed and it looks perfect. got a couple more small mods in the works but will be posting my first pictures on here soon. i initially bought 295/65/20 nitto trail grapplers (35.47" x 12.13") but they just wouldn't fit. ended up switching to ridge grapplers instead which are about 3/8" narrower in that size. i'm running the factory 20" wheels so it's been a bit more problematic than an aftermarket wheel would be. FYI for those out there considering using the factory 20's with this lift kit and 295/65/20's you WILL require a 1/4" spacer in the front only. the tires will touch the UCA when the truck is in the air but once it's on the ground you should have ~3/16" to 1/4" gap. very slight rub on the felt liner but only at full lock. you can run wider tires with this lift + factory wheels, but it'll require bigger spacers and trimming your lugs or lug nuts. my advise is get some aftermarket wheels if your budget will allow it. Edited November 11, 2019 by Shoguns80 1 Quote Link to comment Share on other sites More sharing options...
Shoguns80 Posted November 24, 2019 Share Posted November 24, 2019 On 11/11/2019 at 10:59 AM, Shoguns80 said: just got my 4" Readylift installed and it looks perfect. got a couple more small mods in the works but will be posting my first pictures on here soon. i initially bought 295/65/20 nitto trail grapplers (35.47" x 12.13") but they just wouldn't fit. ended up switching to ridge grapplers instead which are about 3/8" narrower in that size. i'm running the factory 20" wheels so it's been a bit more problematic than an aftermarket wheel would be. FYI for those out there considering using the factory 20's with this lift kit and 295/65/20's you WILL require a 1/4" spacer in the front only. the tires will touch the UCA when the truck is in the air but once it's on the ground you should have ~3/16" to 1/4" gap. very slight rub on the felt liner but only at full lock. you can run wider tires with this lift + factory wheels, but it'll require bigger spacers and trimming your lugs or lug nuts. my advise is get some aftermarket wheels if your budget will allow it. And here she is.... 3 Quote Link to comment Share on other sites More sharing options...
SatinSilvy Posted November 24, 2019 Share Posted November 24, 2019 Did you use the spring spacer that the kit came with? Not sure why they want you to take the spring off, put the spacer on and compress the crap out of it. I feel like it would ruin the ride.???? Quote Link to comment Share on other sites More sharing options...
SatinSilvy Posted November 24, 2019 Share Posted November 24, 2019 I installed mine today. I got the wheels and tires just waiting on lugs, sensors and for some reason my wheels require a hub centric ring? Weird. So it’s still on stock rubber for now. 2 Quote Link to comment Share on other sites More sharing options...
