lord.kinbote Posted August 6, 2019 Share Posted August 6, 2019 Afternoon. So before I installed Android Auto, bluetooth was working perfectly with my Samsung S9+ phone. After I installed Android Auto, my phone indicates that it is connected to the truck via bluetooth, but the truck says the device is not connected when I select the phone from the touch screen. If I connect the USB cable to the phone and truck, Android Auto loads and everything works fine. Problem is, I do not always want to use Android Auto and would rather just use the bluetooth/phone to select music, etc. I noticed, even if not connected with the USB cable, the Android Auto loads up when I get in the truck. Is there a way to disable this so the functionality is the same as before installing Android Auto? Quote Link to comment Share on other sites More sharing options...
Mountain boy Posted August 7, 2019 Share Posted August 7, 2019 (edited) Delete the phone and re pair it. You should see 2 phones one Bluetooth and one cabled. At least that’s how apple is. I had to do this had the same problem. Edited August 7, 2019 by Mountain boy Quote Link to comment Share on other sites More sharing options...
DiverRick Posted August 7, 2019 Share Posted August 7, 2019 (edited) On 8/6/2019 at 4:39 PM, lord.kinbote said: Afternoon. So before I installed Android Auto, bluetooth was working perfectly with my Samsung S9+ phone. After I installed Android Auto, my phone indicates that it is connected to the truck via bluetooth, but the truck says the device is not connected when I select the phone from the touch screen. If I connect the USB cable to the phone and truck, Android Auto loads and everything works fine. Problem is, I do not always want to use Android Auto and would rather just use the bluetooth/phone to select music, etc. I noticed, even if not connected with the USB cable, the Android Auto loads up when I get in the truck. Is there a way to disable this so the functionality is the same as before installing Android Auto? There is a setting in the App itself. Turn off "start App when Bluetooth connected" (or words to that effect.) You don't want that. The App will still load if you connect via USB. Edited August 7, 2019 by DiverRick 1 Quote Link to comment Share on other sites More sharing options...
Tbevo Posted August 8, 2019 Share Posted August 8, 2019 i have this problem with apple carplay, everytime i hook up via usb cable, i have to repair the phone via bluetooth settings 1 Quote Link to comment Share on other sites More sharing options...
lord.kinbote Posted August 8, 2019 Author Share Posted August 8, 2019 15 hours ago, DiverRick said: There is a setting in the App itself. Turn off "start App when Bluetooth connected" (or words to that effect.) You don't want that. The App will still load if you connect via USB. Sweet. I found the setting and disabled. I will test out today - appreciate the help! Quote Link to comment Share on other sites More sharing options...
Sjordan Posted August 8, 2019 Share Posted August 8, 2019 33 minutes ago, Tbevo said: i have this problem with apple carplay, everytime i hook up via usb cable, i have to repair the phone via bluetooth settings This is odd you have this issue with apple. My wife and I talk about how seamlessly the audio transfers when you unplug/plug in your phone between bluetooth and apple carplay. Her jeep does not work nearly as well as my truck. I've had the truck about 4 months and haven't re-paired it since the day I got it. Quote Link to comment Share on other sites More sharing options...
