Slop in steering?
I have a 2014 1500 Denali that has terrible slop in the steering. I have to constantly steer back and forth to keep her between the lines.  Does anybody else have problems like this? Any ideas of where to look or what it is?  Thanks
I don’t believe that’s it.  You have to turn the steering wheel about 3/4 of an inch before it starts turning. You can tell it’s in the steering column
It might be a bad steering rack.  I believe there was a tsb or a recall.  You have to find out what’s wrong. Take it to a good front end shop for an alignment and diagnoses. Research the recalls, as well.  Bad part might be covered by GM.
the steering gear/rack is electronic . it really dont get slop in it persay. you can have a bad shaft that goes from the column coming through the fire wall to the gear it self. the column has a bolt at the bottom of the it inside the truck at the fire wall, one that connects the shaft to the other shaft and one that connects the lower shaft to the gear.
typically in these type of steering gears if you have an issue its hard to turn/steer
slop can be caused by tires, steering shaft, inner/outer tie rods , control arms, alignment.
  • 1 year later...
Did you resolve this issue? I have some play in my steering wheel (2014 Silverado 1500 LTZ).
