  • Sign Up
Hub assembly noise?
How’s it goin fellas, Gotta 2009 Silverado 2500HD 6.0l 6L90. I have BF Goodrich All Terrain TA/KO2, the newest style with the aggressive sidewalks (the older original style looked much better).  I have a terrible humming noise, 90% sure it’s coming from front end. I called my tire guy, and told him these tires are killing me with this hum. It’s at any and all speeds over 15mph. He told me check wheel hubs, which I did. I know they are known to go. Truck has 73,000mi in it. From left was replaced around 40,000. I tried every test you can put wheel bearings and hubs through. They are tight! Driving I possibly here less humming when turning left. So that would indicate left hub possibly going bad. I replace it, use skf hub assembly. Still humms, tried all different tire pressures, still humms, replaced right side hub assembly, still humms, replaced all shocks and steering stabilizer with Rancho 5000’s. Still humms, no brake dust shrouds rubbing. I’m outta ideas other than the tires again. Tires have 5,000 miles on them, and I rotate every 3,000.  Any ideas? Thanks!!
Reply to this topic...
