BCM reflash for LEDs
2 hours ago, GTPprix said:
But it doesn’t buy you all the other cool stuff we can do while we are in there such as extend remote start run time, fogs with high beams, extra flashes on flash to pass speed limiter removal etc etc etc ;)
Thats true!
You could set a bunch of other things up while they got it.
If they could have made my A/C settings while using remote start, look at last used settings, I would have done it for sure!
5 hours ago, SailorX said:
I have used resistors also and they last about a year also you have to splice the harness and they have to be mounted. I know it’s possible and easier just to have the computer programmed. So just trying to find a way.
Maybe you bought really cheap resistors?  Or didn't mount them to a heat sink?
I follow a number of forums, and you are literally the first post I have come across with the problem of the resistors failing regularly.
I've had resistors on my truck for about 2.5 years now, no sign of a problem, and it's my work truck that I drive around the city every day.
Edited by davester
Greatness is what I’m reading!!!
Heres what im using its 2-50w resistors in line for each light. I mounted them on a piece of aluminum. The new setup is to just use a single 100w resistor for each light. Ive had these on my truck for a long time. Zero issues.
  • 1 month later...
