Anyone know center bore diameter for new trucks?
4 hours ago, Ericruiz911 said:
Want to get some hub centric rings made and was wondering if anyone knew the factory hub diameter on these new trucks.
Thanks
Hasn't changed. What thickness spacer are you looking for?
So it's still 78.1? Really thought it would have changed being a completely new Truck. Not going for spacers, only hub centric rings to center aftermarket wheels on hubs
Edited by Ericruiz911
Nope, no change in bore.  Still 78.1 and 6x139.7.  The offset has changed as well as the angle of the spokes on the wheels to clear the larger 4 piston calipers. Be sure your wheels will clear the calipers.
  • 3 weeks later...
I'm going through this now with my Custom.
78.1mm hub is correct, I verified it with spacers this past Sat at the tire shop. Unfortunately I found out my wheels have 106mm hubs as I didn't check before hand. Oops. My Googlefu found these on Amazon and they fit my new wheels perfectly. https://www.amazon.com/gp/product/B07MXNPFCK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Only good news I had Sat was the wheels clear the bump on the caliper with the spacers. Yay.
Round 2 of getting my new wheels installed this Friday.
-Patrick-
Edited by KEEPER OF SECRETS
  • 4 weeks later...
