Philipgonzales3 Posted June 4, 2019 Share Posted June 4, 2019 Can the transfer case be put in Neutral? I didn't see anything about this in the manual. 2019 4WD LT Z71 Texas Edition here. Quote Link to comment Share on other sites More sharing options...
Philipgonzales3 Posted June 4, 2019 Author Share Posted June 4, 2019 Nevermind. Found it on page 240. Shifting Into N (Neutral) To shift into N (Neutral): 1. Start the vehicle. 2. Shift the transmission to N (Neutral). 3. Shift the transfer case to 2 m. 4. Apply the parking brake and/or brake pedal. 5. Press 2 m five times in 10 seconds until the N (Neutral) graphic starts flashing in the instrument cluster. When the shift is complete, the graphic stops flashing. If the parking brake and/or brake pedal is not applied within 20 seconds, the transfer case will remain in the original state. 6. If the transmission is not shifted into N (Neutral) or the vehicle has not slowed to 5 km/h (3 mph) within 20 seconds, the transfer case will remain in its original state. This will be indicated in the instrument cluster. Quote Link to comment Share on other sites More sharing options...
