Transmission fluid check & refill procedure 2019 Trailboss LT?
I believe it's like the cars, where there is a fill/ check plug in the pan. With the vehicle level, and the trans at a specific temp (the 6L80/ 90 cars are something like 100-125*) you pull the plug with the vehicle running and watch for a little trickle to come out. If none comes out, add fluid until it does.
Edited by carkhz316
