hoping its just an electrical issue but every so often my oil pressure gauge drops to 0 at idle, but never sets off an idiot light or message on the info screen and my voltmeter jumps between 9 and 14 volts the entire time I'm driving, but again no alarms or message.  Any one else experience this?
The alternator only has a load on it in certain situations.  It does this for fuel economy, and for many other scenarios, just to name one.  So the battery voltage dropping could just be the alternator not actually charging.  I have noticed my voltage fluctuate quite a bit, anywhere from 10-14 volts.
4 hours ago, Wayne3593 said:
Is the oil pressure dropping to zero when start/stop is activated?
when I noticed it the truck was running, that was the first thing I checked, its so quiet I have to look at the tach sometimes to be sure
I must not be keeping up with new tech very well,  I didn't know that the alternators were able to turn off and on,  I'm going to have to get myself caught up:D
1 hour ago, BringTheRain403 said:
They've always had voltage regulators on them. You alternator only puts out as much power as the truck needs to operate...
Sent from my Pixel 2 XL using Tapatalk
true,  but they were not controlled by a computer, only voltage.  I rebuilt too many to count in the 90's and know how those worked,  just hadn't keep up with the changes is all.  The guage dropping to about 10 volts was something new for me to see,  I've never had one drop below 12 when the engine was running unless there was a failure
Edited by wizard4878
Man, I don't think it should drop to 10 volts. Something is wrong
There is a larger mark between the 9 and 14, which in my mind should be 11.5,  it will drop just below that,  then eventually go back to 14.
Or check voltage at the battery with a dvom and compare to the gauge. Mine never drops below 12ish (the cluster gauge is hard to read. Even in auto stop that is driving its usually around 13-14.
