ILSilverado Posted May 30, 2019 Share Posted May 30, 2019 (edited) 4 hours ago, newdude said: Okay all you jinglers and janglers... Hot off yesterday's press: This ONLY APPLIES TO TRUCKS WITH RPO CODE SU4 Front Differential, which are the AAM supplied 8" front differential. Woo Hoo! Well this pretty much opens it up to a non conformity buy back since no official repair is available. I owe you a great big kiss! "JINGLE"!!! LOL tell me GM isnt in this forum on a daily basis. Edited May 30, 2019 by ILSilverado Quote Link to comment Share on other sites More sharing options...
newdude Posted May 30, 2019 Share Posted May 30, 2019 13 minutes ago, ILSilverado said: Woo Hoo! Well this pretty much opens it up to a non conformity buy back since no repair is available. I owe you a great big kiss! Repair is coming per the PI. Quote Link to comment Share on other sites More sharing options...
ILSilverado Posted May 30, 2019 Share Posted May 30, 2019 (edited) 14 minutes ago, newdude said: Repair is coming per the PI. Makes no difference as long as 30 days pass after the problem is reported to GM. It could be 6 months before they come up with a fix. Most lemon laws state a permanent fix for any non conformity must be performed within 30 days. I'm going on 25 days now. The key is the last line "When a Repair is Available" Edited May 30, 2019 by ILSilverado Quote Link to comment Share on other sites More sharing options...
Chambo Posted May 31, 2019 Share Posted May 31, 2019 Mine started this noise today. 3900 miles in. Quote Link to comment Share on other sites More sharing options...
Chevy sad Posted May 31, 2019 Share Posted May 31, 2019 Maybe the Salvation Army will buy they from Chevy for their x-mas collections. Quote Link to comment Share on other sites More sharing options...
Chambo Posted May 31, 2019 Share Posted May 31, 2019 32 minutes ago, Chevy sad said: Maybe the Salvation Army will buy they from Chevy for their x-mas collections. Why are you still here trolling along? Pretty sure I’ve only seen your input on this thread and you’re already annoying. Go be a Ford guy somewhere else. 2 Quote Link to comment Share on other sites More sharing options...
Chevy sad Posted May 31, 2019 Share Posted May 31, 2019 Sorry, I just thought it was funny. Never envisioned hurting anyone with that comment. I honestly feel for those effected. Quote Link to comment Share on other sites More sharing options...
Thejet07 Posted June 3, 2019 Share Posted June 3, 2019 So dealership called today. Service writer was fully clear on what’s being replaced but did say he definitely knows it’s half shaft which is on backorder. I hope this fixes it. I want to put a level and block and I do t want to hear them say that was the cause. You know dealerships. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RAYS B4U Posted June 4, 2019 Share Posted June 4, 2019 Last Saturday I listened to the ringing bell for about 6.5 hrs on my trip, and to say the least....it was very annoying!! I just checked my build sheet and I have the SU4 - AXLE FRT! From what I've read here, it starts happening after it has warmed up good, so today I'll take it for an extended drive and see if I can get it to do it. If I can then I'll swing by my dealer and give them this info and see if I can take a tech for a ride. ================= Info from my Build Sheet: Model: CK10543-2019 SILVERADO 1500 4WD CREW CAB Build Date: 08/27/2018 Build Plant: Z SU4 - AXLE FRT L87 - ENGINE, 6.2L ECOTEC3 V8 WITH DYNAMIC FUEL MANAGEMENT Quote Link to comment Share on other sites More sharing options...
ILSilverado Posted June 4, 2019 Share Posted June 4, 2019 (edited) 24 minutes ago, RAYS B4U said: Last Saturday I listened to the ringing bell for about 6.5 hrs on my trip, and to say the least....it was very annoying!! I just checked my build sheet and I have the SU4 - AXLE FRT! From what I've read here, it starts happening after it has warmed up good, so today I'll take it for an extended drive and see if I can get it to do it. If I can then I'll swing by my dealer and give them this info and see if I can take a tech for a ride. ================= Info from my Build Sheet: Model: CK10543-2019 SILVERADO 1500 4WD CREW CAB Build Date: 08/27/2018 Build Plant: Z SU4 - AXLE FRT L87 - ENGINE, 6.2L ECOTEC3 V8 WITH DYNAMIC FUEL MANAGEMENT They just issued a stop fix bulletin on May 29th for this issue. look in this thread around page 6. It states more or less that GM is working on a fix but its not officially out yet and dealers should stop trying to repair it until they release the fix. Edited June 4, 2019 by ILSilverado Quote Link to comment Share on other sites More sharing options...
Rsktm300xcw Posted June 4, 2019 Share Posted June 4, 2019 How did you get your build sheet? I would like to look at mine. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
fish_guru Posted June 4, 2019 Share Posted June 4, 2019 Just e-mail or call GM Customer Service and ask them for it. They will need your VIN. 1 Quote Link to comment Share on other sites More sharing options...
David Cantara Posted June 5, 2019 Share Posted June 5, 2019 WOW I have had the same issue, first they said transfer case, then rubber boot, and then differential, then the one (differential) they replaced came back with noise worse than before, after warm up rotating noise.. trippy! I have had this problem from day one of ownership. I'll be sure to book mark this thread see how many others are out there. I am currently still waiting on fix for this issue. 1 Quote Link to comment Share on other sites More sharing options...
aha1987 Posted June 5, 2019 Share Posted June 5, 2019 I would like to know everyone's build date... you can find it on a gray sticker when you open the driver door. I would like to think that most of the trucks that are having this issue have a build date from 2/2019 and earlier... reason I believe this is because I own a truck built in 08/2018 and have been driving a loaner truck that was built in 04/2019 that isn't making this noise. Quote Link to comment Share on other sites More sharing options...
aha1987 Posted June 6, 2019 Share Posted June 6, 2019 On 5/30/2019 at 12:27 PM, newdude said: Okay all you jinglers and janglers... Hot off yesterday's press: This ONLY APPLIES TO TRUCKS WITH RPO CODE SU4 Front Differential, which are the AAM supplied 8" front differential. New dude, where did you find this info? Quote Link to comment Share on other sites More sharing options...
