Jingle jingle underneath only in 2wd
Ok. I’m going to go ahead and be the guinea pig and let them do the fix lol. It looks like this is the supposed fix since it dates August 5, and this was the same info that my SA had. Cross your fingers everyone!  Truck goes in Monday.
6 minutes ago, atst2000 said:
Oh ok...well guess that settles that lol....any insight on what to do next then?
Get the part numbers for the fix your dealer is offering first. See if they are different from the part numbers listed on the pic I posted. If they are the same, skip it.
Ok I will call them up and ask and let them know....so guess I should just live with it?
There should be a 4th part as well (the stub shaft, which is supposedly the cause of the issue). I'm not sure what the part # is though.
Edited by jbith
Autocorrect error
So just curious has ANYONE had this supposed "Fix" with the bulletin that came out Aug. 5 had it actually resolve the noise?  For me the noise isn't so much a jingle per say but more or less a scraping noise like the wheel hitting against the brakes
I'm waiting in my dealer to get the parts in. Mine sounds like a wheel bearing that squeals in a repetitive cycle. Only happens when it's hot out (90+) and I've driven a while (30 minutes or more)... Guessing that combo causes something to expand. Thankfully I don't have a long drive to work so I don't have to hear it frequently.
Guys, read the line above the table listing the P/Ns. Maybe I’m mistaken but I read that as there isn’t a full list of parts yet (updated when stub shaft is available.....). I’d be pointing this out & having the dealership confirm they’re doing this correctly & have all the parts.
On 9/5/2019 at 2:57 PM, Z06JPB said:
What’s all this then?
https://static.nhtsa.gov/odi/tsbs/2018/MC-10149050-9999.pdf
There seemed to be a problem with SU5 and SU8 GM axles? The original date was was from August 2018. As of June 24, 2019, the restriction had been lifted so dealers can work on the axles:
https://static.nhtsa.gov/odi/tsbs/2019/MC-10162153-9999.pdf
The whole time I was under the impression the SU4 was the only axle with problems.
Again, not an expert but that is version A of the PIP & the document was later revised lifting restrictions apparently because they confirmed the issues were only related to SU4. I’m guessing they needed all axles to see which ones were the culprit(s)?
My understanding from my dealership was that the stub shaft is a special order part currently and not generally available. Apparently there's a special process they have to go through to order it along with additional documentation that they need to send to GM.
Makes sense. So that P/N is missing from the PIP attached above....so unless the stub shaft is also at the dealer.....no sense in taking it in yet (IMO). And if it’s the same revision (B - dated 05AU19) that one owner (Thejet07) has already reported not so good results, things may not be looking so good.
Maybe this has been discussed already & forgive me if I’m rehashing but I’d think if the 4 P/Ns from Jet’s attempted repair were known (3 in chart should be consistent) & you other guys asked your dealer to check the P/Ns currently available to them, particularly the stub shaft, then you’ll get an idea if each truck is getting the same thing. If it is all the same, then I wouldn’t get my hopes up too much that this PIP revision is the answer.
I hope this is clear & not introducing confusion.
30 minutes ago, atst2000 said:
Ok so from what I’m understanding if it doesn’t include the stub shaft it’s going to be a waste taking it in?  I tried emailing my SA yesterday morning and no reply yet. I’ll call and ask.
I would tend to think so, based on what’s shown on the PIP, starting at the bottom of page 1 & continuing on page 2. It explains the stub shaft needs to be ordered from the Warranty Parts Center using a special form & from where the dealer can obtain that form. The PIP then states the PI (Parts Information) will be updates when the stub shaft is available through CC&A (customer care & aftersales - see here for that info: https://mccicorp.com/work/gm-cca/).
I read all of that to mean that the stub is a special order for now & once it becomes available via what is probably the "normal" ordering process through CC&A, then the PIP will be updated so the parts list can be updated and show the stub shaft & its P/N.
Please, don’t take my word for it. Go over this with your advisor, service manager, shop manager or technical bulletin specialist.
