They are the exact same length as your stock one. I did the same thing when I leveled out my truck and had to install spacers. You will still need to turn the torsion bars up to get it level, the shock wont help with that.
This is incorrect. The 4600 Bilstein is OEM spec for length and travel.
5100 has a longer shaft to accommodate up to 2" of lift.
21 hours ago, Country Bumpkin 2003 said:
So, I have a 2018 Silverado 1500 LT Z71-Crew Cab, and I’m about to install the Bilstein part listed in the title. It says on there website that it is a suspension lift of 1.85. Is this enough to level out my truck “evenly”...???
No, the truck will not be even. There will still be a slight rake from back to front, but will for the most part appear level looking from the side.
It all depends on standard suspension, Z71 etc.  All trucks are not created equal.
I promise you when I installed my 5100 they were the exact same length as the stock ones. They say they will work up to two inches over stock but the actual length is no different.
