  • Sign Up
2017 Silverado...front/rear level or level/body lift?
Hello everyone,
Been doing Alot of reading and searching regarding lifting my 2017 Silverado Z71 crew cab. There's so much info out there it can be overwhelming.
I have already decided to NOT go with a suspension lift due to cost and not wanting to change the factory ride. Considering I am wanting a visual lift for cosmetic reasons only, I see no reason as to spend the extra money when I am looking for no performance enhancement.
I am however conflicted between going with a 2.5" front level and 1.5" body lift, or a front 2.5" front level AND rear level. I am wanting to stick with 18" wheels and try to get a 33-34" tire under the truck.
While cost is a factor, I want to ensure the longevity of my truck and not cause TOO much wear and tear on the trucks components. So if one of the above options is "better" as far as less wear and tear on stock components than the other, that would be a factor as well.
Any info is appreciated.
Reply to this topic...
