Dash lights staying on
Describe how long they are staying on.
They come on when you open the door, while running, and will stay on until you open the drivers door with the key out (engine not running).
The timer that you set is for the exterior lights, not interior, they just fade to "nothing" along with your dome light when it is dark out.
Don't think there is a way to over ride this feature.
Have you looked inside of the truck from the outside (hope that makes sense) to see if they are off at night?
2 hours ago, Jopher said:
Yes...that's how I noticed it last night.
Try this, not sure if you have the ability to check for codes or not:
Pulled codes and got this, B2615-passenger compartment dimming #2 circuit malfunction. So I tried opening the passenger door also as someone else suggested and it worked. The dash lights cancelled out. Not a solution to a fix, but a lead.
  • 3 years later...
