4-By-4 Posted September 12, 2003 Share Posted September 12, 2003 Sure hope someone can give me a hand here. I have a new 03 2500 HD with the trailer package. Just received a prodigy brake controller with the correct 03 harness plug. I "thought" I plugged the controller into the cable, with the plug in the proper slot in the firewall box, and got an indication. I removed the cable from the controller to mount it, and when I plugged it in, no joy on the controller. So, I measured the voltage across the black and white wires, which are supposed to be ground and 12v. Got zippo. Do I have to add a fuse in there somewhere? Nothing came with my "kit". What fuses would I check to see if I somehow blew a fuse? Thanks for your help.... Link to comment Share on other sites More sharing options...
c5hd Posted September 12, 2003 Share Posted September 12, 2003 You;re not supposed to need a fuse. It sounds like if it worked before you unplugged it, you either blew a fuse or damaged the wire harness. The owners manual says the trailer fuse is Stud #2 in the underhood fuse box. Also try hitting the brake pedal after it is hoked up. The controll goes to sleep after 15 min of non-use. It should power cycle when you plug it in, but you never now. Also if you had the door open for a while, and the truck shut the accessory power off to save the battery. Just some ideas. Link to comment Share on other sites More sharing options...
N900WM Posted September 12, 2003 Share Posted September 12, 2003 And make SURE you have the correct wiring harness! My dealer installed a 2002 wire harness in my 03 and I had similiar problems till they figured it out. Link to comment Share on other sites More sharing options...
Shaners Posted September 12, 2003 Share Posted September 12, 2003 I'd check the fuses under the hood... the fuse you are looking for is one of the "jumbo" or "maxi" fuses. Link to comment Share on other sites More sharing options...
4-By-4 Posted September 12, 2003 Author Share Posted September 12, 2003 You guys are good! I looked in my manual, and the only thing I saw about trailer brakes is about hooking them into the hydraulic lines. Must have to look deeper. Anyway, the fuse on the stud #2 is gone. The lid says it's size is dependent on the use, it was a 30 amp. Strange the controller itself would blow a 30 amp fuse! The cable has the correct part number from the place I got it for an 03. Guess I'll search around for a pin out to make sure. Anyone have any links for that? thanks for the help so far.. Link to comment Share on other sites More sharing options...
