2.7 Turbo 4 Fan Club
1 hour ago, KARNUT said:
I don’t know where the advantage is with the 2.7. The latest car and driver for 2023 models has the 5.3 doing better fuel mileage on HWY. Maybe low end grunt for light pulling?
For starters, it doesnt have the lifter issues... just sayin
Edited by Rob Sye
  • Thanks 1
I got my eye on it. It’s an interesting engine. GM burned me a few times with their little experiments. 5.7 diesel, 6.5 diesel. I had a cylinder deactivation engine for about a year. For the first time I bought without doing much research. I dropped it off for exhaust thought I blew it up on the way home. It went into deactivation mode. Thought I had a helicopter following me. Joined this forum found out about that engine and unloaded the truck. I was ready to do some mods being it was going to be my retirement truck. I had a 92 that was already done so I stayed with it instead. That convinced me to stay with old stuff like my avalanche. They just keep getting worse, I’ll pass on the new stuff. I’m curious about the maverick. Time will tell.
I have a hard time believing they saw better highway mileage with the 5.3L. Was it towing?  No load, 4 passengers I see 25MPG+ all day on the highway.
  • Thanks 1
1 minute ago, Rob Sye said:
For starters, it doesnt have lifters... just sayin
Not that lifters are a problem, that failure rate is much lower than the vocal ones make it out to be. This does have a variable lift lobe with sliding shafts activated by a pin. Pick your poison, they state it is very robust so failure rates should be very low like the AFM system (excluding the bad batches) but you know the few failures will be very vocal as it is a system that makes a simple motor more complicated for fuel savings...
Fuel mileage, cost and drivability; it is a few mpg better overall combined because it is much better in the city. Highway is only one part of the equation, but even then GM and the powers that rate them show the highway mpg of the 5.3 less than the 2.7. Then you have the lower upfront costs and the superior lighter duty pulling power with all that low end torque. For those that aren't self-conscious with the whole V8 or nothing it really is a superior motor in many cases to the 5.3 depending on use (which most if being honest probably fall under).
Tyler
Like I said Car and Driver.
Tyler
I’ve been reading about multiple lawsuits over lifter failures. A little or a lot depends if it’s you. I heard the same BS with the 5.7 diesels clunky steering column and bad speedometer s. It usually comes to a head down the road.
Yeah I just read it. Maybe I typically stay below 75 on long trips and that’s the sweet spot. My foot is heavier in the city getting the truck up and moving so I understand the 2.7 isn’t great in the city but on the highway I’m pretty happy with it.
Interesting on the C&D report.
Lower initial price, 4 fewer rotating connections and stuff to break to cause issues, including burning fuel.  I suspect that if geared properly and RIGHT SIZED for the towing need the L3B does as well or better than the old technology.  Towing FAST will kill MPG.
As Grumpy shares his Dads and my 52' Ford 239 CI flathead V8 did just fine when geared right.
We are so spoiled by technology and driving like lunatics anymore.
Edited by customboss
add some more brilliance, LOL
I'm at altitude ( 9000' msl)  cold, hellacious winds, snow, mud, rocks, in and out of 4WD burning E15 that is 86 octane min and get 20-22 overall average.  In ideal low country 2WD ops with 87 octane E10 crapfuel it easily gets 25-28  mpg avg on highway in a 2022 LTD Trail Boss.  I drive 60-65 mph on hwy unless its I-25 where I run 75 mph.
Speed noted.
It could be something simple like gearing. You would think Car&Driver would make things equal. I remember reading spec sheets years ago you could actually get a tow package with a 5.3 that would rate higher towing than the 6.2. With the TQ rating and where it reaches max TQ. The 2.7 should be able to use a taller gear. And get good mileage. Empty anyway.
  • Thanks 1
For all the L3B fans.....latest oil sample taken with great results but it had to be topped up with Renewable Lubricants 5w20 HD low ash because I was out of RLI.  Look mom we stopped the aluminum wear.  Still in SAE grade too. The RLI products are tough and made in America by Mom and Pop in Griggy OH.
Currently has a fresh load of Havoline ProRs 5w30 which is working quite well in cold here.
Thanks to Nick, site sponsor known as Black02Silverado for the ISO certified oil analysis service.
Nick Mikitka
Independent AMSOIL Dealer
Synthetic Advantage LLC
Phone: 910-290-2371
Nick Mikitka
Phone: 910-290-2371
Interesting that the water went up so high.  Is this due to the colder months?  At least the FD stayed down.
Everyone comments on my 1993 7.3 NA diesel f-250 in town. Lots of offers to buy it, and lots of comments on what a great tow truck it is. The fact is I have towed some pretty crazy stuff with it……slowly. It is do to gearing and suspension. It had 185hp and 388ft lbs of torque new. My 2.7 trailboss kicks it’s butt power wise and comfort ect…. We are truly spoiled now a days.
    247.6k
    2.6m
    Goat House
    Goat House
  • Who's Online   5 Members, 1 Anonymous, 564 Guests (See full list)
