build date
1 hour ago, bbjohnny said:
That is what I thought but it is not there!
Check between driver's door and passenger door almost by passenger hindge. Mine is farther back than expected.
I also got the build sheet from the dealer with all the codes and it says 11/28/18 for build date. My door sticker says 11/18.
Ok, I apologize, you guys are correct!  There is a tag way down low that does have the date on it.  It is as described, between the driver's door and the rear door.  Mine is below the bottom hinge.  Thank you!
1 hour ago, OnTheReel said:
[email protected]
...will email you your entire build sheet, including the exact day of manufacture.
Is there any way to just look it up online by chance?  Thanks for this info either way, very helpful!
Don’t think there is, but if you email them today I would almost guarantee you’d get the sheet by tomorrow. They are very quick. I emailed them on a weekend and they got right back to me.
If you have access to the truck, the other way is to snap a shot of the QR code on the door post sticker (replaces the old service part code sticker that used to be in glove box).
There are many smartphone apps that can be used to display the information in the QR code.
https://gmrepairinsights.com/2018/06/label-lookup-qr-code-replaces-gm-spid-label/
  • 2 months later...
