2016 Silverado LTZ - Mid Travel to Prerunner Build
AZ_RADO_RNR
Hey All -
I have a 2016 Silverado LTZ 4x4 5.3 w/ 8SPD that I just paid off and am looking to go full long travel. Here are the current truck specs:
Front Shocks - King 2.5 Adjustable Reservoir
Upper Control Arms - Camburg Tubular UCAs
Rear Shocks - King 2.5 Adjustable Reservoir
Tires: 35x12.5x17 BFG KO2s
Wheels: 17in Method NVs
Lighting: 2-Baja Designs XL80s (SDHQ A-Pillar Mounts)
Other: Range AFM Delete
The current set up is ok, I can keep up with stock Raptors on certain trail runs. Given that I want more out of this truck, I'm looking at the following long travel kits:
  • Camburg
  • LSK Suspension
  • Dirt King
I'm leaning towards the Camburg & DK kits as they're only +3.5 on each side vs. +4.5 for the LSK Kit. My garage isn't wide enough right now to accommodate +4.5 and will barely accommodate +3.5.
Here are the other mods to follow in the next 2 months:
  • Rear Bed Cage
  • Whipple Supercharger
  • +3 FiberWerx Fenders (All Corners)
  • 37x12.5x17 BFG KM3s
  • 4.10 Gears
Looks great man! Can’t wait to see it done! Love seeing more and more people doing long travel, I know I love mine! Although I’m a bit jealous of your soon to be plans for the whipple. I’d love to do the same but am unable to at the moment, let me know how much better it moves those 37’s. I put 4.56’s in mine and it made quite the difference I can only imagine if I had a supercharger lol
Here are some new additions to the truck, all parts purchased and installed by the SDHQ team in Gilbert, AZ.
New items:
Camburg Racing Long Travel Kit
Deaver U182s Leaf Pack
Mazzula Shackle & Hanger Kit
DirtKing Lower Arm Weld Washers
DirtKing Heavy Duty Upper Arm Alignment Cam Tabs
SDHQ Skid Plate
FiberWerx +3 Front Fenders
I'll post better photos once I have the fenders painted. Bonus photo of my truck next to BIGRED811s for those interested in seeing a comparison of a wider Silverado vs. Stock.
Love this build. You’ve chosen many of the same products I’ve been looking at. Would love to hear some feedback about the Deaver U182 springs. I have 4.56 gears with 33”-34” tires. I recommend you go shorter than 4.10s. Either 4.56 or 4.88 with your tire size. My highway RPMs are only 2250 at 70mph. The gears alone make you feel like you have a blower.
Maybe I missed seeing a driveshaft listed on your build. If you haven’t upgraded it yet, I’d start looking. I went with a one piece 5” aluminum shaft. Some guys like the two piece shafts.
Love watching this build. Thanks for sharing.
@300 Blackout Do you have any recommendations on two piece drive shafts?
[mention=178152]300 Blackout[/mention] Do you have any recommendations on two piece drive shafts?
Unfortunately, I don’t.
@1SLOW1500 is who I’d reach out to for some brand recommendations on two-piece driveshafts. Although he usually focuses on dropped rides, he’ll probably know a few reputable companies for your application.
Inwould run a steel smaller diameter 2 piece. It is adjustable on the middle crossmember to allow you to lower or raise the truck and allows for more clearance. Plus the steal is much more durable then aluminum.
They have a normal and then a high performance option. Not much price difference.
Alldrivelines.com
Any reason you stayed with leaf? I see people do this that stay in a class. But a 3 or 4 link is better and rides better. Then inbound coil overs and tube and shaft rear swaybar with delink.
Alldrivelines.com
3/4 link costs a lot more unless you get someone to build a 1 off daily driver link kit. Without one you have to relocate the gas tank and pay a ton for fabbing of the links. Would also assume modifying the stock axle to accept the links while being strong enough would be a lot of work
Reply to this topic...
