2020 HD Ordering Updates, 2019 HD Production End Dates
2 hours ago, redwngr said:
They will all be the new body style, but the production starts are staggered.
(wasn't til March 2019 that the reg cab 1500 started production)
Well if that new funky body style looks like i wont be replacing my 2006 then. May have to look at Sierra or yuck something else or get nothing new.
15 hours ago, lryfer said:
So with this said for building a 2020 silverado is the double cab going to be same body style as the 2018 or 19 LD model? I do not like the 2019 look at all - actually cant stand it.
Anyone know by chance?
Order guides in the first post are for the new body 2020 HD.  2020 Double cabs start August and you should be able to order about mid June.
GM will however be making 2019 HD Double cabs until 12/13/19 (ordering ends 8/23/19) to hold over demand while they ramp up the 2020 prodcution.  So, anyone wanting a 2019 body double cab still has time.
If you are talking 1500 double cab old body (2014-2019 body), those stop orders 7/26/19, and production ends 11/1/19.
Edited by newdude
GMC colour names; chev uses different names, but same RPO's.
These are upper trims, some colours not available on all trims.
White Frost Tricoat1     G1W
Cardinal Red2    G7C
NEW!  Pacific Blue Metallic3    GA0
Quicksilver Metallic1    GAN
Summit White    GAZ
Onyx Black4    GBA
NEW!  Dark Sky Metallic3    GJI
Red Quartz Tintcoat4    GPJ
NEW!  Carbon Black Metallic3    GCI
NEW!  Brownstone Metallic5    GNK
Notes:
1 - Available at extra charge. Not available with (4SB) AT4 Trim.
2 - Available at extra charge. Not available on (4SB) AT4 or (5SA) Denali.
3 - Available at extra charge. Not available at Start of Production.
4 - Available at extra charge.
5 - Available at extra charge. Not available on Denali. Not available at Start of Production.
Model Home
Ok, help me clarify if you can. I’m wanting to order a 2020 AT4 so my only color options are anything with a 3,4, or 5, correct?
Also, Summit White has no number but its a primary color so that should also be an AT4 option, right?
If you're wondering what black looks like on an AT4 I saw these pictures on Instagram....
3 and 5 are "not available at start of production", so unless you're wanting to wait until it becomes available....and we don't know when that will be
For now, might be easier to think of 1, 2, and 3 as unavailable.
So, currently only 3 are available to order on 2020HD 2500 AT4:
Summit White, Onyz Black, Red Quartz,
To be added in future, but date(s) unknown:
Dark Sky Metallic, Carbon Black Metallic and Pacific Blue Metallic, Brownstone Metallic
Thanks! Current truck is Red Quartz and while the color is super deep and clear when clean it’s almost as bad as the black for showing dirt!
I’m really interested in the Brownstone Metallic but I don’t want to wait past YE 19 to buy (gotta beat the tax man)!
On ‎4‎/‎17‎/‎2019 at 7:35 PM, dlockwood26 said:
Has anybody seen a confirmation of production date on the 2020HD Crew cabs?
No updates on the build out/start up yet, just the month.  I'll try and update this thread when something comes across my way.
Just curious. We placed an order for a 2500HD sierra on the first of April.  One of the things we ordered was code "PTT" for the trailer tire monitoring sensors. Looking at the Ordering information posted on this site it appears that to use it you need the (U1D)  In-vehicle trailering app to be installed from the factory.
Looking through all the codes on the primary order sheet we received from dealer, I do not see the (U1D) included.
Any idea if it could be added once it gets to the dealer or if ordering the (PTT) automatically adds the (U1D)?
Haven't ordered a new car since we ordered the 66 Pontiac and at that time everything was a line item with out all the packages. Almost made it simpler.
Thanks for any input.
What trim level is truck?
PTT         Trailer Tire Pressure Monitor Sensors, includes set of 4 sensors. Sensor functionality requires (U1D) In-vehicle Trailering App to be ordered with the vehicle and installed by the factory. Sensors will be shipped loose with the truck and will need to be installed on trailer by customer. System is capable of monitoring up to 6 wheels. Additional or replacement sensors are available through GM Accessories
 - on SLE - Requires (ZL6) ProGrade Trailering System or (PDQ) Preferred Package.
- on higher trims
U1D is a 'ref only' rpo code; meaning it doesn't get listed on order sheet; (comes with a trim level or included with some other added on option)
PTT is always an option so needs to be added
U1D    In-vehicle Trailering App, System, includes checklist, trailer maintenance reminders, trailer security alerts, trailer mileage, tow/haul reminder, trailer electrical diagnostics and Trailer Tire Pressure Monitor System module
- on SLE - Included and only available with (ZL6) ProGrade Trailering System or with (PDQ) Preferred Package. Includes trailer tire pressure monitoring alert ONLY when (PTT) trailer tire pressure monitor system is factory ordered and sensors are installed
- on SLT AT4 and Denali  - Standard, but Includes trailer tire pressure monitoring alert ONLY when (PTT) trailer tire pressure monitor system is factory ordered and sensors are installed
PTT and U1D not available on base Sierra
(long winded way of saying that if trim is SLT/AT4/Denali, it's not listed because it's part of the trim level; if it's an SLE then it must/should have either ZL6 or PDQ; and if it's base trim Sierra the order is wrong and will need to be corrected)
Do you have the Order Number?
Do you know what Event Code the order is at?
- on higher trims
Its an SLT.
I've got a BAC # 118354
I don't know if that is the order code or not.
Dealer did call about a week ago and said they had received notice that everything was accepted and hopefully have another update in a week or so.
Thanks for your help...Sonny
I think I entered reply in the quote instead of where I should have so here is correction.
Its an SLT.
Edited by Sunshine39
Where is Satin Steel Metallic like on the MY19 All New 1500 Sierra?  I wanted a 2500 AT4 or Denali in that color.  Dam It Man.  I have Ebony Twilight Metallic Denali now so assume that is the same as MY2020 Carbon Black Metallic.
It's only the same if it has the same RPO code.
Carbon Black is shown as a new colour, and as not available at start of production.
 Carbon Black Metallic    GCI    WA-621D
Ebony Twilight was new for 2019 -- but is a different RPO  (GB8) and touch-up (WA-384A)
 Ebony Twilight Metallic     GB8    WA-384A
They could be similar, but paintshops will need to know which one they are matching....
Some colours get used for years, bu it's also not uncommon for GM to use colours for only one year.
And to further complicate it, chev and gmc often (but not always) use a different name for the same colour code.
GB8 is Ebony Twilight on Sierra, but is called  Mosaic Black Metallic on silverado.
Edited by redwngr
