No more AWD?
1 hour ago, jrhaines2 said:
Am going to trade up from my 07 Denali and it looks like AWD is no longer available.Was the change in 2015?
From my owners manual (2018), AWD is applied as needed if you're in AUTO:
If equipped, use the transfer case
knob next to the steering wheel to
shift into and out of four-wheel drive.
All of the lights will blink on then off
momentarily when the ignition is
turned on. The light that remains on
will indicate the state of the
transfer case.
If the indicator mark on the switch
does not match up with the light
then that likely means the switch
was moved when the ignition
was off.
The indicator mark on the switch
must line up with the indicator light
before a shift can be commanded.
To command a shift rotate the
transfer case switch to the new
desired position. The light will blink
meaning that the shift is in progress.
When the shift is completed the new
position will be illuminated. If the
transfer case can not complete a
shift command, it will go back to its
last chosen setting.
The settings are:
N (Neutral) : Use only when the
vehicle needs to be towed. See
Recreational Vehicle Towing 0 430
or Towing the Vehicle 0 430.
2 m (Two-Wheel Drive High) : Use
for driving on most streets and
highways. The front axle is not
engaged. This setting provides the
best fuel economy.
AUTO (Automatic Four-Wheel
Drive) : Use when road surface
traction conditions are variable.
When driving in AUTO, the front
axle is engaged, and the vehicle's
power is sent to the front and rear wheels automatically based on
driving conditions. This setting
provides slightly lower fuel economy
than 2 m.
Do not use AUTO mode,
if equipped, to park on a steep
grade with poor traction such as ice,
snow, mud, or gravel. In AUTO
mode only the rear wheels will hold
the vehicle from sliding when
parked. If parking on a steep grade,
use 4 m to keep all four wheels
engaged.
4 m (Four-Wheel Drive High) : Use
this position when extra traction is
needed, such as when driving on
snowy or icy roads, when
off-roading, or when plowing snow.
4 n (Four-Wheel Drive Low) : This
setting engages the front axle and
delivers extra torque. Choose 4 n
when driving off-road in deep sand,
deep mud, or deep snow, and while
climbing or descending steep hills
Edited by SS502
Automatic Four Wheel Drive is the AWD you are referring to.
My 2018 has Auto, 2 hi, 4 hi and 4 low. (But when the knob is Auto, the dash actually says AWD on the screen)
In Auto it sends power to the front at all times and regulates what wheels gets power. it doesnt lock anything like the 4 lo or 4 hi.
I LOVE it in the rain! Take a corner and punch it and you just go, no slipping or sliding.
  • Thanks 1
Exactly...4 high and 4 low are the true 4WD and Auto is the AWD
An AWD system employs a front, rear and center differential to power all of the wheels. Sensors in those wheels take hundreds of readings per second. These sensors monitor each wheel's traction and the center differential increases and decreases power to each wheel as needed. This allows for fantastic control in all sorts of weather conditions and doesn't hinder your maneuverability.
At low speeds, AWD isn't as robust, so don't expect that raw power you'd get from 4WD. The same goes for pure towing power, which is why you mainly see AWD systems on cars and crossovers, not big trucks and SUVs.
Another difference between 4WD and AWD is that 4WD can be switched on and off. AWD is always on, so if you're seeking out top-tier fuel efficiency, then AWD might not be the best route to go. On the other hand, there are advantages to always having AWD engaged. AWD's ability to instantly adapt to changing road conditions, like ice and snow, without having to flip a switch takes human forgetfulness out of the equation. It's a much safer way to drive.
I will also add that an AWD vehicle does not have low range.
Yes my 07 has AWD and is always on and I was looking at 15's and newer and seen the selector.I had an 02 and 07 Denali with AWD and AWD was only available on the Denali version  with no other options available as far as AWD or selectable  4WD.
You didn't specify what Denali you are looking at. I just looked at 2 different 2018 Denalis, they were both AWD, a terrain and Acadia. The Yukons and Sierra's are 4wd. So yes you can get an AWD Denali.
Sent from my Moto G (4) using Tapatalk
They were Yukons.I looked at a 15 and 16 and were both 4wd.
1 hour ago, Mdsjohna said:
Both of the trucks you looked at had auto 4. Which is essentially the same as AWD in operation. This is obtained through the use of clutch plates in the transfer case which just happens to be how many AWD systems operate with a clutch. I think AWD has a differential.Auto 4 is only putting power to the front wheels in the event of traction loss on the rear as I understand.AWD applies power to all 4 wheels evenly until more or less traction is called for on each individual wheel and auto 4 applies power to the front and rear evenly as I understand.
There are lots of different AWD implementations: Quattro, 4matic, xdrive, etc. They all have implementation differences, so there is no single definition of AWD.
In 2007 Denali Yukons, it seems like GM used a NP246 transfer case, and maybe just deleted the selector button? In any case it works by sending up to a 40%/60% power split between front and rear. It didn't have separate clutches for left and right. Sounds like the new Corvette might, and the Acura NSX has. But no trucks thar I know of.
Sent from my SM-G960U using Tapatalk
  • Thanks 1
    247.7k
    2.6m
    Semyon Glinkin
    Semyon Glinkin
  • Who's Online   3 Members, 0 Anonymous, 696 Guests (See full list)
