4x4 shifter not shifting properly
Ok I got the bodylift installed tonight, only problem I need to lengthen the 4x4 linkage. Because: 2HI is (4HI), N (2HI) and in between neutral and 2LO is the real neutral then 2LO is 2LO.Do you get it............:smash: So I need to make the linkage longer but they did not supply the extra piece! :( Would any of you guys know the proper length if that piece? Thanks
I'm not sure what to tell you, but I know some others have installed a body lift with a floor shifter and didn't use an extension, and didn't have any problems either.
Try to contact chevy4x4trucks, here at GM-TC, he's one that installed a B/L on a floor shifter truck.
Sorry I wasn't any more help than that. :smash:
You might be able to adjust it. Re read your directions that came with the BL to see if you didnt accidently miss anything. When we did a BL on my friends '95 it said to loosen the bolts on the linkage and then we had to adjust and retighten them at the end. He has had no problems with it.
