- 0
2007 Chevy Trailblazer P0171 Plz help
Similar Content
- 3 answers
- 2,568 views
- 11 replies
- 9,700 views
- 10 replies
- 12,499 views
- 7 replies
- 2,228 views
- 2 replies
- 1,786 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 18 Members, 0 Anonymous, 2,399 Guests (See full list)
Question
H.USA
Hello, I have a Chevy Trailblazer 2007 LT 4wd high miles, I have a P0171 and I've been trying so hard to figure it out without going to a repair shop.
The Frame freeze data show a P0171 recorded at Coolant temp 206, Idle RPM , LT Fuel trim 26%, the Oxygen sensor and the MAF readings appear normal to me.
Live Data now is showing LT 29% on idle numbers improve to below 10% if increase RPM even slightly and get worst very quick on IDLE. I also noticed RPM isn't 100% stable on idle but nothing major. Sometimes the check engine light will suddenly go away to come back later, I also notice a gas cap light on from time to time if that matters
I already cleaned Throttle body, MAF , my Air filter was recently replaced. I visually double checked all the air hoses no obvious crack, Breathing cap was cracked so i replaced it but nothing changed. I tried a water test on the manifold gasket but the engine isn't shivering when I toss water, I don't have access to a smoke machine. I can hear a little whistling from the manifold but I'm not sure. couple days ago I had the Throttle body control error but it cleared when I cleaned it and it never came back. Another test of pressing the brakes on Live date show a huge increase in Short term fuel trim to 32.5%.
Please help me because The car isn't worth spending thousands on it and it might not even work, is there anything else I can try, is it possible Fuel pump or fuel filter?
Thank you so much
Edited by H.USALink to comment
10 answers to this question
