Custom Trail Boss Console Upgrade?
On 3/14/2020 at 12:21 PM, JLind19Custom said:
Does anyone have a lead on a storage organizer of the top portion of the console?
I've seen a slip-in organizer tray on ebay before, like this one:
https://www.ebay.com/itm/Center-Console-Organizer-Insert-Tray-For-2019-GMC-Sierra-1500-Chevy-Silverado/233382805963
I'm not sure if that is the correct one, but there are others on there too.
I found jump seat with upper and lower storage  on E BAY last week.https://www.ebay.com/itm/15-16-17-18-19-BLACK-Cloth-Jump-Seat-Chevy-Silverado-GMC-Sierra/383478553007?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
$250.00 from customization shop. It did not have the air vents on the back panel, but was easy to switch the parts from my old one. Looks like they have 3 left. Pretty easy to swap out.
  • Like 3
Do you have a 19 or 20?  The link doesn't look like it's for the latest gen.
New body 19. The one I got was just like my original but with storage. They have changed their posting image now, I guess they must be out of the newer ones.
On 2/4/2020 at 1:24 PM, Dunn said:
I may have one for sale in near future as I might do full center console on my RST. ill post it if and when that happens, still almost brand new.....I have jumpseat (under seat locked storage) as well that I believe has to come out for full floor console....mine is dbl cab but has rear ports though different than a CC I think, not sure
Do you still have this available?
On 6/13/2019 at 12:13 PM, Jeffed said:
I purchased the upper part of the armrest from the dealer for $490 Cdn$.  The bottom part apparently is multiple part and was super expensive (i think about $1000).
Anyways, it was a bit of work, but at least I have a bit of storage.  I can deal with that issue now.
You need to remove the driver seat and will require a T50 and T55 bit.
I recently ordered this part. How did you remove the side plastic plates to get to the bolts to do the swap? I want to make sure I do it correctly and don't break something stupidly.
They just pop off. There's not really a special to do it other than slowly. Just be careful. If the clips break glue them. I put my pieces back on with one broken piece ( which I was not happy about) but they still fit together and stayed fastened with no issues. Message me if you are concerned and I will send you pics of the clips to give you and idea of how they connect.
Sent from my Pixel 2 XL using Tapatalk
20200403_140106.thumb.jpg.74d526f888e7fae45caafbe90ea8d826.jpg20200403_140116.thumb.jpg.ac14930d94f8be2d2abf24123932e390.jpg
I just ordered the same and installed it with zero problems, THANKS! my truck is a 2020 2500HD Duramax WT made 8/19. I just swapped over my rear vents to the new seat, SO MUCH STORAGE NOW!
@Julio13
@Dan L Posted them from what he found on EBay, they are a Direct fit for 2020 Silverado 2500HD.
"I found jump seat with upper and lower storage  on E BAY last week.https://www.ebay.com/itm/15-16-17-18-19-BLACK-Cloth-Jump-Seat-Chevy-Silverado-GMC-Sierra/383478553007?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
$250.00 from customization shop. It did not have the air vents on the back panel, but was easy to switch the parts from my old one. Looks like they have 3 left. Pretty easy to swap out."
