Alpine restyle DVD issue
Hey all,
   I installed the Alpine X110 SRA and am having an issue. Was hoping others in here also have it and might be a wizard.... I installed the bypass, and everything works. I get DVD video in motion. Menus all work without the parking brake, etc. But this weekend I had a long drive with my son so I grabbed a few DVDs for him to watch from the back seat, but when it got to the point on the DVD where you are at the menu and would select "play", I couldnt select play via touching it nor was there a menu present on the screen to try and select play. My remote also does not work. I have tested the battery with a volt meter and it is good, replaced the battery, nothing.
Any ideas?
3 hours ago, 1SLOW1500 said:
I would try it on the screen. What bypass model? I never had a issue with mine.
I forget which one. Just the simple one that I watched a guy on YouTube use. I talked with him and he hasn't had this issue. There's no buttons on my screen to push in order to select play. The only button displayed is the one to change the aspect ratio. "Wide, fit, etc"
