500 miles into 2019 SLT and started experiencing a clunking when coming to a stop. Doing some research, sounds like a harsh 3-1 downshift has been an ongoing issue with GM trucks. Took it to dealer and rep experienced it as well during a test drive. All tests and diagnostics came back normal and they told me it's the transmission adaptive function learning. Not buying this at all. Anyone experience this?
Is this the 8 speed? Sounds exactly like the issue I had with my 16.
Sent from my SM-G965U using Tapatalk
30 minutes ago, gchu69 said:
Yes the 8 speed.
This is how I fixed it.  After the C1 re-learn it was 100% better.  Decided to do the C4 learn too to be 100% sure.  Took about 30 minutes early one saturday morning when there was no traffic.
https://gm.oemdtc.com/6777/16-na-019-information-on-transmission-adaptive-functions-and-correcting-low-mileage-harsh-shifts-slips-or-flares-2016-2017-buick-cadillac-chevrolet-gmc
To Learn C1 (For 6-7 or 3-1 Shift)
  1. Pressure Learns:
Note: It is recommended to utilize a road with a speed limit between of 30-45 mph (48-72 km/h) for this procedure.
  • Shift the transmission into 6th gear with the PRNDM in the M position. Obtain an engine speed between 1000 and 1600 engine rpm. Maintain this condition for a total of about 5 miles (8 km). Cruise control may be used and has been found to result in faster learning of the clutch values.
  1. Volume Learns:
    • Complete 15 light throttle 6-7 upshifts at approximately 15% throttle to further learn C1.
I also did this:
To Learn C4 (For 1-2, 5-6, or 7-8 Shift)
  1. Pressure Learns:
Note: It is recommended to utilize a road with a speed limit between of 40-45 mph (64-72 km/h) for this procedure.
  • Shift the transmission into 7th gear with the PRNDM in the M position. Obtain an engine speed between 1000 and 1750 rpm. Maintain this condition for a total of about 5 miles (8 km). Cruise control may be used and has been found to result in faster learning of the clutch values.
Important: Application Specific Express & Savana Vans Pressure Learns:Perform 10 normal mode 7-6 coast down shifts (zero/light brake) to learn the C4 Return Spring.
  1. Volume Learns:
    • Complete 15 light throttle 1-2 upshifts at approximately 15% throttle to further learn C4.
Edited by m3n00b
When I first got mine, it did the same thing. Especially when rolling to a stop. I took it to the dealer with 250 miles, .there was no TSB, the said it may just be the transmission learning and may go away.
Sure enough, I’m a little over 1900 miles and it’s gone. It hasn’t done it for the last 1200 miles or so.
  1. Pressure Learns:
  1. Volume Learns:
I also did this:
  1. Pressure Learns:
  1. Volume Learns:
Appreciate it. Saw this online but wasn't sure if anyone had success with it.
Thanks. Had a "clunk" free day yesterday so hopefully it's gone.
Did it happen to come and go? It stopped completely for a few days but started up again just today.
It did, it was of and on. Sometimes it was worse than others. Sometimes I’d go a few days with nothing.
Hi, gchu69. Sorry to hear about this clunking concern. If you’re thinking about re-visiting your servicing GM dealership about your situation, I would be happy to work alongside them, to provide an additional layer of support. I hope to hear from you soon.
Anthony J.
  • 10 months later...
  1. Pressure Learns:
  1. Volume Learns:
I also did this:
  1. Pressure Learns:
  1. Volume Learns:
On the volume learns, I am doing this after the pressure learn. So go the 5 miles and then speed up into the 6th gear, and use the + to go to the 7th? Just keep doing this last part over and over?
I have the same problem... harsh 3-2-1 down shifts .... problem seems most prevalent on warm days 85º + with trans temp 178º - 180º...... Started around 1700 miles went away because outside temps cooled off but then returned at 2900 miles on a 91º day
Edited by 609dry
Duplicate
    247.8k
    2.6m
    Mark Phil
    Mark Phil
  • Who's Online   2 Members, 0 Anonymous, 692 Guests (See full list)
