G80 3.21/3.41 gear break
I cannot find separate part numbers for the 2014+ G80 carrier for the 3.08 vs 3.42 gear sets (only found GM 23156744).  I HAVE found separate part numbers/items for the open differentials (3.21 and down & 3.42 and up) (22943115 & 22943116).
Correct me if I am wrong, but isn't the G80 a separate carrier than the standard stock open carriers?
Would a G80 equipped truck with 3.08 gears require the ring gear spacer to go to 3.42+ gears?
  • 1 year later...
On 10/14/2018 at 5:49 AM, silveradosid said:
the g80 is the same i switched my 308 open carrier to a g80 from gm
Just to confirm, did you move the stock 308 gears over to the G80 (from a 2014-2018 donor) successfully?
Go to the guys who supplied GM with your axles, DemandAAM.com  They'll have a pdf for the complete unit and all the parts too.  You have one of two 12-bolt Salisbury axles, a 9.5 or 9.76 if memory serves.
