HvyChvy334 Posted February 15, 2019 Share Posted February 15, 2019 21 minutes ago, Ben Berkenpas said: There are a number of people installing 1 1/2" or 2" under strut lift without any short term problems. Time will tell if it ends up putting premature wear on the ball joints and steering parts but it certainly works to level the truck. If you go to the forum about fitting 35s on a AT4/Trailboss there are pics and comments. I guess this could be a good temporary option if you want to get 35s under the AT4/TB until someone comes out with an option that can address any of the bad angles. I just might try it for now. It’s the Motofab 1.5” on amazon they’re using right? Quote Link to comment Share on other sites More sharing options...
Ben Berkenpas Posted February 15, 2019 Share Posted February 15, 2019 4 minutes ago, HvyChvy334 said: I guess this could be a good temporary option if you want to get 35s under the AT4/TB until someone comes out with an option that can address any of the bad angles. I just might try it for now. It’s the Motofab 1.5” on amazon they’re using right? Yep. I think going to do the same! Quote Link to comment Share on other sites More sharing options...
HvyChvy334 Posted February 15, 2019 Share Posted February 15, 2019 5 minutes ago, Ben Berkenpas said: Yep. I think going to do the same! Think the 1” would be a little safer? Quote Link to comment Share on other sites More sharing options...
Ben Berkenpas Posted February 15, 2019 Share Posted February 15, 2019 3 minutes ago, HvyChvy334 said: Think the 1” would be a little safer? Probably, but the 1 1/2 would look cooler!? Quote Link to comment Share on other sites More sharing options...
HvyChvy334 Posted February 15, 2019 Share Posted February 15, 2019 6 minutes ago, Ben Berkenpas said: Probably, but the 1 1/2 would look cooler!? ? You right! Quote Link to comment Share on other sites More sharing options...
Ben Berkenpas Posted February 21, 2019 Share Posted February 21, 2019 Just got the level installed! Motofab 1 1/2 under strut spacer. Went on in about an hour and looks perfect! $21 on eBay can't go wrong. Quote Link to comment Share on other sites More sharing options...
silveradonationfan15 Posted February 21, 2019 Share Posted February 21, 2019 42 minutes ago, Ben Berkenpas said: Just got the level installed! Motofab 1 1/2 under strut spacer. Went on in about an hour and looks perfect! $21 on eBay can't go wrong. Do you have any more pictures of your truck and do you have a link to the kit you ordered off e bay. Thanks Quote Link to comment Share on other sites More sharing options...
Ben Berkenpas Posted February 21, 2019 Share Posted February 21, 2019 5 minutes ago, silveradonationfan15 said: Do you have any more pictures of your truck and do you have a link to the kit you ordered off e bay. Thanks Don't have any more pics with the level installed as I literally just finished the install an hour ago. Here is the link to the kit though. https://www.ebay.com/itm/1-5-Front-Leveling-lift-kit-for-Chevy-Silverado-2007-2019-GMC-Sierra-GM-1500-LM/322399957905?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D12944cb6a313433cb086d6fce4b6c58d%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dpp%26sd%3D322399957905%26itm%3D322399957905&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A260e1de8-3625-11e9-b7ac-74dbd18036ed|parentrq%3A1219de931690a993ed6d1f05fffba6ec|iid%3A1 Quote Link to comment Share on other sites More sharing options...
Ben Berkenpas Posted February 21, 2019 Share Posted February 21, 2019 1 hour ago, silveradonationfan15 said: Do you have any more pictures of your truck and do you have a link to the kit you ordered off e bay. Thanks Quote Link to comment Share on other sites More sharing options...
Sierra Dan Posted February 22, 2019 Share Posted February 22, 2019 Looks good Ben. Thanks for sharing. I am sure many will follow in your footsteps Some Ridge Grapplers would look great with your setup. Quote Link to comment Share on other sites More sharing options...
Ben Berkenpas Posted February 22, 2019 Share Posted February 22, 2019 1 hour ago, Sierra Dan said: Looks good Ben. Thanks for sharing. I am sure many will follow in your footsteps Some Ridge Grapplers would look great with your setup. It does need some larger tires, but one thing at a time!? 1 Quote Link to comment Share on other sites More sharing options...
jj_marshy Posted February 23, 2019 Share Posted February 23, 2019 DOES ANYONE KNOW IF YOU CAN FIT 35'S ON THE TRAIL BOSS WITH IT LEVELED? THANKS! Quote Link to comment Share on other sites More sharing options...
z1boss Posted February 23, 2019 Share Posted February 23, 2019 3 hours ago, jj_marshy said: DOES ANYONE KNOW IF YOU CAN FIT 35'S ON THE TRAIL BOSS WITH IT LEVELED? THANKS! Yes you can but it depends on the width of the tire and the offset of the rim. For example a 35x12.5s on a rim with a positive 20ish offset wont rub but a rim with a 0 mm offset will rub slightly. What size tire and rims do u have in mind exactly? Quote Link to comment Share on other sites More sharing options...
jj_marshy Posted February 26, 2019 Share Posted February 26, 2019 I’ll be doing the TOYO M/T 35x12.5x18 on positive 18 offset wheel. Currently have 33’s on it and want to go bigger. 33 looks to small I think. Thanks Quote Link to comment Share on other sites More sharing options...
z1boss Posted February 26, 2019 Share Posted February 26, 2019 2 hours ago, jj_marshy said: I’ll be doing the TOYO M/T 35x12.5x18 on positive 18 offset wheel. Currently have 33’s on it and want to go bigger. 33 looks to small I think. Thanks You should be fine since your rim has a positive 18 offset. Worst case scenario, it will rub the slightest amount but I dont think it will. Quote Link to comment Share on other sites More sharing options...
