275 70 18 tires
Awwmann
You can go to a 305 on these trucks with stock wheels with no rub. My fat 33x12.5's rub when turning left full lock. Depends on rim specs too, there is a website that has all the Chevy rim specs, it should also have the offset stamped on the inside of the wheel. Mine are a crazy +27mm which pushes the tire very close to the UCA and swaybar which is why it rubs. a .25" wheel spacer would fix this but I don't steer full lock often.
