Squeaking noise when starting engine
Hey fellas,
I have a 2014 with the 5.3 engine with around 80k miles and every time i start the engine it makes a squeaking noise either Hot or Cold. Sounds like belts but changed them all, lube them and still there?
Anyone with this issue?
Thanks.
  • Replies 31
Top Posters In This Topic
4 minutes ago, jpmiami said:
Hey fellas,
Thanks.
I had this issue with my '14 Sierra.
Thought it was the starter, but I found the flapper valve in the exhaust was the culprit.
It was worse and louder when warm.  Tried lubricating but no luck, so I just clamped it open.
Try clamping your exhaust flapper valve open, start up and see if that works.
Aside from that could be your starter or a belt etc, but my gut says you have same issue I had.
26 minutes ago, starman8tdc said:
What?
    I'm not talking about the pulley bearings on the tensioner, i'm talking about a loose or worn out tensioner spring, which would reduce the tension on the belt, resulting in a squeal. But yes, it could be the pulley bearing too I guess.
I will look at that tomorrow.
Well, to me it sounds like your battery is weak....  seems like a slight hesitation on start like it is not getting the CC Amps it needs.
This could be causing stress on your belt? Sounds like the belt to me.
Definitely from the engine/front engine area.
Do you have a warranty?
