RKMichael Posted August 21, 2018 Share Posted August 21, 2018 Hello all, I just purchased a 2017 GMC crew cab 4x4. I have had 7 F150's and finally nbit the bullet and went with this beauty! I do not want to lift it as to not void the warranty so I am just going to put a 2.5 inch leveling kit on the front. It currently has 275/55/20's on it. I am going with an all terrain tire on it and am keeping the factory rims for now. I will eventually get something with an offset so the tires will stick out from the fender well around an inch or so. So, with all that being said, what it the largest size tire I can go with right now without having to worry about rubbing issues? Can I do a 33x12.50x20? Quote Link to comment Share on other sites More sharing options...
Ry•Rye Posted August 21, 2018 Share Posted August 21, 2018 Hello all, I just purchased a 2017 GMC crew cab 4x4. I have had 7 F150's and finally nbit the bullet and went with this beauty! I do not want to lift it as to not void the warranty so I am just going to put a 2.5 inch leveling kit on the front. It currently has 275/55/20's on it. I am going with an all terrain tire on it and am keeping the factory rims for now. I will eventually get something with an offset so the tires will stick out from the fender well around an inch or so. So, with all that being said, what it the largest size tire I can go with right now without having to worry about rubbing issues? Can I do a 33x12.50x20? I'm running 33x12.5x20 but my wheels are -44 offset so they rubbed....alot. but with stock wheels I've seen many run it with very light rub if not any. Sent from my SM-N950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
RKMichael Posted August 21, 2018 Author Share Posted August 21, 2018 Thanks for the reply! Sharp ride by the way! 1 Quote Link to comment Share on other sites More sharing options...
Ry•Rye Posted August 21, 2018 Share Posted August 21, 2018 Thanks bud. Check this thread out..https://www.gm-trucks.com/forums/topic/153363-2014-leveling-kits/All leveling kit pics and what everyone hasSent from my SM-N950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
SierraBear Posted August 21, 2018 Share Posted August 21, 2018 Hello all, I just purchased a 2017 GMC crew cab 4x4. I have had 7 F150's and finally nbit the bullet and went with this beauty! I do not want to lift it as to not void the warranty so I am just going to put a 2.5 inch leveling kit on the front. It currently has 275/55/20's on it. I am going with an all terrain tire on it and am keeping the factory rims for now. I will eventually get something with an offset so the tires will stick out from the fender well around an inch or so. So, with all that being said, what it the largest size tire I can go with right now without having to worry about rubbing issues? Can I do a 33x12.50x20? On a 14, r65s will barely rub with the wheel turned to lock with a 2.5" lift with no extension and the wheel wells pinned back.Sent from my SM-N950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
RKMichael Posted August 30, 2018 Author Share Posted August 30, 2018 Thanks for all the replies. I ended up putting a rough country 2.5 inch kit on the front. Did it myself with the help of a buddy of mine. Only took us 6 hours! LOL. Also went with 275/65/20 BFG KO2's on it. A tad bit narrower than what I wanted but they fill up the fender well pretty good. 1 Quote Link to comment Share on other sites More sharing options...
Lgetz Posted August 30, 2018 Share Posted August 30, 2018 Good looking truck Michael. Make sure to have it aligned ASAP. Quote Link to comment Share on other sites More sharing options...
Silverado629 Posted September 1, 2018 Share Posted September 1, 2018 35x12.50s will fit without a problemSent from my SM-N950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
menacing_gmc Posted September 2, 2018 Share Posted September 2, 2018 305/65/18 with -12 Methods on a 3" level Only rubs full crank in reverse Quote Link to comment Share on other sites More sharing options...
zbutle4 Posted February 6, 2019 Share Posted February 6, 2019 On 8/30/2018 at 8:45 AM, RKMichael said: Thanks for all the replies. I ended up putting a rough country 2.5 inch kit on the front. Did it myself with the help of a buddy of mine. Only took us 6 hours! LOL. Also went with 275/65/20 BFG KO2's on it. A tad bit narrower than what I wanted but they fill up the fender well pretty good. Do you have any more pictures of the truck like this? I have the same truck but want to level and keep stock wheels with large tires. Quote Link to comment Share on other sites More sharing options...
mcdavis Posted February 6, 2019 Share Posted February 6, 2019 Thanks for all the replies. I ended up putting a rough country 2.5 inch kit on the front. Did it myself with the help of a buddy of mine. Only took us 6 hours! LOL. Also went with 275/65/20 BFG KO2's on it. A tad bit narrower than what I wanted but they fill up the fender well pretty good. So 34x11's will fit with a 2.5 and no rub? Good info.Are you a little nose high, or is it just the pic?Sent from my SM-G955U using Tapatalk Quote Link to comment Share on other sites More sharing options...
4weight Posted February 7, 2019 Share Posted February 7, 2019 On 9/1/2018 at 1:51 PM, Silverado629 said: 35x12.50s will fit without a problem Sent from my SM-N950U using Tapatalk X 2 with stock wheels you should not have an issue. When you go aftermarket with offset I cannot comment. Quote Link to comment Share on other sites More sharing options...
ftwhite Posted February 7, 2019 Share Posted February 7, 2019 35x12.50s will fit without a problemThat's different then me. With a 2.5 level from Fox coilovers on a 2018, I couldn't fit 34.3 x 11.6 without rubbing even after trimming.Can someone provide pictures of 35s on just a level kit? Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
njk4o5 Posted February 7, 2019 Share Posted February 7, 2019 8 hours ago, ftwhite said: That's different then me. With a 2.5 level from Fox coilovers on a 2018, I couldn't fit 34.3 x 11.6 without rubbing even after trimming. Can someone provide pictures of 35s on just a level kit? Sent from my SM-G960U using Tapatalk what wheels were you running and what offset pretty sure 35x12.5 will rub on stock wheels on one of the suspension parts. and if you go -24 offset or larger they rub on the fender liners. -12 offset you might just squeeze them in there Quote Link to comment Share on other sites More sharing options...
4weight Posted February 7, 2019 Share Posted February 7, 2019 10 hours ago, ftwhite said: That's different then me. With a 2.5 level from Fox coilovers on a 2018, I couldn't fit 34.3 x 11.6 without rubbing even after trimming. Can someone provide pictures of 35s on just a level kit? Sent from my SM-G960U using Tapatalk My bad guys, I have 33x12.5x20's. I too bet 35's would rub for sure. Quote Link to comment Share on other sites More sharing options...
