ISO Service Parts Identification Help
I am in need of some Service Parts Identification Help. This is the sticker in the glove-box. Where can I find something to de-code all the information in it? Any help at all would be appreciated. image.thumb.jpeg.93fb2fe0620390d914b86d31c4cb03d2.jpeg
Send an email to [email protected] and request the build sheet. It has all the codes and what they are.
They sent me mine within 24 hours.
Any dealer can use the serial number and print the sheet(s) for you.
Is there a specific thing you are wondering about?
There may users on the forum that can answer some questions about your extended cab standard box.
Important ones:
TK25753:  GMC 4x4 2500 extended cab standard box.
MT1:  4L80E transmission
HVY:  2 inch body raise, indicates being an HD labeled truck.
LQ4:  Vortec 6000, aka the LQ4 6.0.  300hp 365 torque on that generation.
NP2:  Manual shift transfer case.
GT5:  4.10:1 gearing.
50U:  Olympic White exterior.  Code is the U8624 at the bottom.
C6W:  9200lbs GVWR.
JH6:  9900lbs brakes.
K47:  High capacity air cleaner
NZZ:  Skid plates
Z88:  GMC
KC4:  Engine oil cooler
KNP:  Transmission heavy cooling
This is going mostly off of memory other than the paint.
Thank you all so far. I have sent an email for the build sheet - awaiting response. From the link that dsr611 provided, and the ones that newdude supplied, this is what I have so far.
2004 GMC Sierra HD 4X4 Service Parts Identification (Sticker in Glovebox)
TK25753 : GMC 4x4 2500 extended cab standard box
AJ1 : WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
AM7 : SEAT, RR, FLDG
A28 : WINDOW, RR, FULL WIDTH, SLIDING
A95 : SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL
BVS
B71 : MOLDING WHL OPENING, COLORED
CJ3 : HVAC SYSTEM AIR CONDITIONER FRT, MAN TEMP CONT
C6W : GVW RATING, 9200 LBS
DF2 : MIRROR O/S, CAMPER TYPE, SST
DNR
EVA : TEST DVT, EVAP EMISSION REQUIREMENT
E2C
E63 : BODY EQUIPMENT, FLEETSIDE, PUBX
FLT
FT2 : ARM, LH, TORSION BAR SPRING ADJ (FT2)
FT3 : ARM, RH, TORSION BAR SPRING ADJ (FT3)
GMC : PLANT CODE PONTIAC, MI, USA
GT5 : AXLE REAR, 4.10 RATIO (DUP WITH GT8)
HVY : 2 inch body raise, indicates being an HD labeled truck
JH6 : BRAKE, HYD POWER, 4-WHEEL DISC, 9900 LBS
KC4 : COOLING SYSTEM, HEAVY DUTY ENGINE OIL
KNP : COOLING SYSTEM TRANS, HD
KUP : THROTTLE CONTROL ELECTRONIC
K47 : AIR CLEANER HIGH CAPACITY
K68 : GENERATOR,105 AMP
LQ4 : ENGINE, GAS, 8 CYL, 6.0L, MFI, IRON, GM
MT1 : TRANSMISSION, 4 SPD, AUTO W/ELECT CONTROLS H.D. (HYDRA-MATIC
4L80-E)
NA4 : EMISSION SYSTEM, GVW, ABOVE 8500 LB
NF4 : EMISSION SYSTEM CLEAN FUEL FLEET
NP2 : TRANSFER CASE – (MANUAL) – FULL RANGE
NZZ : SKID PLATE OFF-ROAD
PDP
QIW : TIRE ALL, LT245/75R16/E BL R/PE ST TL OOR BL
R6D
R9Z
TFD
UBO : CLUSTER, INST, OIL, TEMP,TACH ,TURBO BOOST
UQ5 : SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DUAL EXTD RGE
VB3 : BUMPER, RR, STEP, CHROME, IMPACT STRIP
VCL
VG3 : BUMPER FRT, IMPACT STRIP
VK3 : LICENSE PLATE, FRT MOUNTING PKG
VQ2
VR4 : TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM
VXS : VEHICLE COMPLETE
V73 : VEHICLE STATEMENT, USA/CANADA
XGK : TIRE FRONT, LT245/75R16/E BW R/PE ST TL OOR 120Q
YD3 : FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE
YD6 : REAR SPRING, BASE EQUIPMENT
YGK : TIRE REAR LT245/75R16/E BW R/PE ST TL OOR 120Q
YK6
ZHH
ZY1 : COLOR COMBINATION, SOLID
Z82 : TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0.
Z85 : CHASSIS PACKAGE, HIGH PAYLOAD FIRM RIDE
Z88 : CONVERSION, NAME PLT GMC
1SW
1SZ
50U : PRIMARY COLOR, OLYMPIC WHITE (U8624)
6C7 : LAMP, DOME PASSENGER
6GK
69I
69V : TRIM COMBINATION, VINYL,
7GK
7Z1 : HORN, DUAL, HIGH NOTE
9L4
9S1
And in answer to redwngr, nothing specific. I just like to have all the information that I can about my rides. I would love to have a Shop Manual for this vehicle.
BVS : STEPS RUNNINGBOARD, SIDE, COLOR
DNR : EQUIPMENT DEALER INSTALLED
E2C : RAPID DELIVERY SYS CUSTOM ORDERS (E/K-TRK CKST)
FLT : FLEET PROCESSING OPTION
HVY : IDENTIFICATION 2 INCH BODY RAISE, H.D. MODEL
4L80-E)
PDP : CONTROL SALES ITEM NO. 133
R6D : CONTROL SALES ITEM NO. 4
R9Z : CONTROL - SALES ITEM NO. 100
TFD : SALES INCENTIVE
VCL : CERTIFICATION EMISSION, CLEAN FUEL VEHICLE, FLEET
VQ2 : FLEET PROGRAM - DEALER ASSISTANCE, HOLDBACK NOT APPLICABLE
YK6 :IDENTIFICATION (SEO)
ZHH : TIRE SPARE LT245/75R16/E BL R/PE ST ALS
1SW : PACKAGE- OPTION 21
1SZ : PACKAGE OPTION-
6GK : SPRING COMPTR SELECT FRT LH
69I : INTERIOR TRIM COLOR,MEDIUM BEIGE/VERY DARK PEWTERINTERIOR TRIM COLOR,VERY DARK PEWTER
7GK : SPRING COMPTR SELECT FRT RH
9L4 : WIRING PROVISIONS 12 VOLT POWER SUPPLY
9S1 : TRIM OVERRIDE VINYL COVERING, SEAT
Did some digging and filled the blanks in red, also fixed my crappy HVY description.
This is the vehicle build sheet that I just received.
Vehicle Build Sheet - 1GTHK29U24E305510.PDF
Vehicle Build Option Codes:
TK25753 : GMC 4X4 2500 EXTENDED CAB STANDARD BOX
AM7 : FOLDING REAR SEAT
A28 : SLIDING REAR WINDOW SLIDING REAR WINDOW
A95 : FRONT RECLINING BUCKET SEAT W/ POWER DRIVER SEAT ADJUSTER FRONT RECLINING BUCKET SEAT W/POWER DRIVER SEAT ADJUSTER
BVS : BLACK TUBULAR ASSIST STEPS ***DEALER INSTALLED***
CJ3 : AIR COND., DUAL ZONE MANUAL (REPLACES AIR COND. IN PKG)
DNR : DEALER INSTALLED EQUIPMENT DEALER INSTALLED
E2C : ORDER TO DELIVERY –EXPEDITE
HVY : IDEN 2 INCH BODY RAISE HD MODEL
4L80-E)
PDP : FULL FLOOR RUBBER COVERING
R6D : BID ASSISTANCE/CE BID ASSISTANCE/CE
R9Z : POMS EXPEDITE-SOLD ORDERS POMS EXPEDITE-SOLD ORDERS/TSE
TFD : RETAIL AMENITY DELETE
VCL : FEDERAL EMISSIONS -CFF LEV 50-STATE EMISSIONS -CFF LEV
VQ2 : FLEET ORDERING & ASSISTANCE
YK6 : SEO IDENTIFIER
ZHH : LT245/75R16/E ALS BW TIRE-SPR
1SW : WORK TRUCK PACKAGE INCLUDES: WIDESIDE BODY *AIR COND., DUAL ZONE MANUAL *CHROME FRONT BUMPER *AM/FM STEREO
1SZ : OPTION PACKAGE DISCOUNT
69I : DARK PEWTER INTERIOR TRIM
9L4 : 12 VOLT POWER SUPPLY
9S1 : VINYL TRIMMED FRONT SEATS
Model: 2004 SIERRA 2500 EXT 4WD
VIN: 1GTHK29U24E305510
Build Date: 03/23/2004
Build Plant: E
