Largest tire with stock 20 inch wheels
I ran a 305/55r20 Nitto Ridge Grappler on my factory wheels with a 2"leveling kit, and they rubbed on the sway bar while turning.  If I could do it again, I would have ordered 285/60r20 or 295/55r20, so that it wouldn't have rubbed at all.  Anything bigger will probably rub if you do any type of articulation while turning, such as going up a steep driveway.
This would be my setup, 2.25” front billet aluminum, 1” rear added. 285/60/20 Ridge Grapplers. Had 275/60/20 KO2’s that didn’t rub at all then put on 285/60/20 KO2’s that barely rubbed, now switched out to the Ridge Grapplers and these rub on the outside edge of the tires only rubbing on backups, Ridge Grapplers are larger diameter, 34” X 11.50 X 20
46 minutes ago, Scooter Scott said:
Control arms on the 2017+ apparently get rubbed on
I don't think that is a year thing.  There are 3 types of control arms that come on these trucks.  Mine are stamped steel, and while my tires rub them at full lock it is so little that it took me a few months of checking them before I ever even saw a mark from it.  Don't sweat it so much, not a big issue unless you go crazy with tire size.
He’s correct about the UCA’s late 2015 the trucks went from aluminum to stamped steel. A neighbor has a 14 CrewCab Z71 they didn’t rub when he leveled it but my 18 did, bought new offset wheels and now it’s all good.
4 hours ago, Scooter Scott said:
I have a 2018. It’s a bit different between these model years
Yah my 2017 has the stamped steel control arms, which are exactly the same for late 15’ to 18’
2 minutes ago, JamesAT18 said:
No rubbing? I hear only KO2's in that size won't rub.
Honestly that's what I was banking on.  The only rubbing I've found so far is hard lock to the right it will rub on the inner fender.  Zip tie should work.  I did not put on a level yet either.
Slight rub with NO leveling kit? Interesting....
