btj_z71 Posted July 12, 2018 Share Posted July 12, 2018 Hey Forum, Regarding the oil drain plug on the 2014 5.3L, is anyone using aftermarket magnetic plugs? What about a magnetic oil filter sleeve, or both? Just curious because last weekend I changed the fluid in my front & rear differentials, and transfer case - all of which have magnetic plugs on them. However, none of of them have filters so, I assume adding a magnetic drain plug or filter sleeve would not make much difference since that is what the oil filter is for. Again, just curious to see everyone's thoughts! Link to comment Share on other sites More sharing options...
mookdoc6 Posted July 12, 2018 Share Posted July 12, 2018 37 minutes ago, btj_z71 said: Hey Forum, Regarding the oil drain plug on the 2014 5.3L, is anyone using aftermarket magnetic plugs? What about a magnetic oil filter sleeve, or both? Just curious because last weekend I changed the fluid in my front & rear differentials, and transfer case - all of which have magnetic plugs on them. However, none of of them have filters so, I assume adding a magnetic drain plug or filter sleeve would not make much difference since that is what the oil filter is for. Again, just curious to see everyone's thoughts! Yes, I use the Dimple plug magnetic.....only one to buy! It is 12x9.75 size don't quote me though can't remember. Link to comment Share on other sites More sharing options...
mookdoc6 Posted July 12, 2018 Share Posted July 12, 2018 40 minutes ago, btj_z71 said: Hey Forum, Regarding the oil drain plug on the 2014 5.3L, is anyone using aftermarket magnetic plugs? What about a magnetic oil filter sleeve, or both? Just curious because last weekend I changed the fluid in my front & rear differentials, and transfer case - all of which have magnetic plugs on them. However, none of of them have filters so, I assume adding a magnetic drain plug or filter sleeve would not make much difference since that is what the oil filter is for. Again, just curious to see everyone's thoughts! Actually, I use the Filter Mag brand 2piece set for Filters too......I just did apples to apples comparison on 5.3L Break in engine and 3.6L both GDI's and the amount of Paste stuck on the walls of the steel filter case after 1st oil change both @ 1000miles was very significant. So the particles are so small on break in which you are FAR PAST is really my concern and when it's needed the most. But the filters mag do work well too........... Link to comment Share on other sites More sharing options...
Nanotech Environmental Posted July 12, 2018 Share Posted July 12, 2018 I put a Fumoto style drain on my '17 & plan to add a filter magnet. Oil changes are a lot easier to manage & less messy now. My previous 06 had a magnetic drain plug & usually had a bit of fine metal spooge on it at each oil change. Was surprised my 17' had no magnet on the drain plug. Link to comment Share on other sites More sharing options...
mookdoc6 Posted July 12, 2018 Share Posted July 12, 2018 6 minutes ago, Nanotech Environmental said: I put a Fumoto style drain on my '17 & plan to add a filter magnet. Oil changes are a lot easier to manage & less messy now. My previous 06 had a magnetic drain plug & usually had a bit of fine metal spooge on it at each oil change. Was surprised my 17' had no magnet on the drain plug. I have yet to rip a oil pan off the ecotec3's do they have a internal magnet? Not sure hopefully I never have to replace mine........ Link to comment Share on other sites More sharing options...
Eddie 70 Posted July 12, 2018 Share Posted July 12, 2018 I have the Fumoto drain valve on mine. I went to Home Desperate and bought a couple of packs of rare earth magnets and stick them to the bottom of the oil filter. I am sure they grab anything that goes by and hold to it. I haven't cut a filter to inspect yet but it is cheaper than a filter mag. Link to comment Share on other sites More sharing options...
Sierra706 Posted July 13, 2018 Share Posted July 13, 2018 I also have a fumoto valve. Biggest regret is not getting the one with a nipple that you can stick a hose on. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
btj_z71 Posted July 17, 2018 Author Share Posted July 17, 2018 Thanks for the replies! I decided to add the Dimple magnetic oil drain plug. They also have magnets for the filter but I did not get those. Curious to see how much the plug gets and will find out during the oil change. Side note for those curious: I used AMSOIL signature series 0w-20 this time along with the AMSOIL oil filter. Link to comment Share on other sites More sharing options...
SWOYER Posted July 22, 2018 Share Posted July 22, 2018 Fumoto, the appeal of magnetic never really held weight to me. Any shavings that get close enough to get stuck on that magnet are bound to rest down there anyway. Either way, the convenience of the fumoto is worth any exaggerated risk. Link to comment Share on other sites More sharing options...
WS6FirebirdTA00 Posted August 24, 2018 Share Posted August 24, 2018 What magnetic plugs are you guys using? I have been looking for some and while I somewhat agree with SWOYER, for a few bucks I don't mind any extra help even if it doesn't do much. Link to comment Share on other sites More sharing options...
Black02Silverado Posted August 24, 2018 Share Posted August 24, 2018 You can also get the magnets out of an old hard drive. Those suckers are strong!!!!! Link to comment Share on other sites More sharing options...
Sierra Dan Posted August 25, 2018 Share Posted August 25, 2018 Great info gentleman Link to comment Share on other sites More sharing options...
Amuro Posted September 6, 2018 Share Posted September 6, 2018 I got a magnet drain plug for my 2016 5.3 C5 Corvette LS1 LS6 Magnetic Oil Drain Plug NEO Magnet Fits: All 97 through 04 Corvettes https://www.amazon.com/dp/B015F2HO3S/ref=cm_sw_r_cp_api_lknKBbFVE01Y0 Link to comment Share on other sites More sharing options...
BigBlueLB756 Posted September 7, 2018 Share Posted September 7, 2018 Save some bucks: https://www.amazon.com/MagiDeal-Magnetic-Drain-Gasket-Chevy/dp/B07G8QDZK8/ref=sr_1_fkmr1_1?s=automotive&ie=UTF8&qid=1536320619&sr=1-1-fkmr1&keywords=dorman+m12x1.75+magnetic+oil+drain+plug Link to comment Share on other sites More sharing options...
