Intermittent No Crank - RESOLVED
Hi all, thought I would post this in the event someone else has a similar problem.
2015 Sierra 6.0. 40k miles.
Truck would not crank when the key was turned. Screens would go blank and nothing. If I tried enough times, I could get it to start. Took it to the dealer, was able to replicate the issue, and dealer diagnosed the truck with a bad ECM.  Tech said normally, it’s the junction block on the battery or even a bad starter.
ECM replaced and all is good. Covered under warranty.
