2018 Silverado Gear Ratio Identification
I can’t figure out what my gear ratio is. I’d like to know how much my truck will/won’t haul. Rather than the normal door jam/glove box sticker showing the RPO codes or Service Parts ID code, my truck has a QR code. A QR reader app gave me the following codes:
AG1
AXK
AY0
AZ3
CJ2
C5Z
DL8
EF7
E63
FHO
G1K
H0U
IO6
I18
JD9
L83
MAH
MSL
MYC
NP5
NTB
QT0
RC4
RD4
RUF
UDD
UQ3
U2K
V8D
WMJ
X88
Z60
1LT
4AA
6YB
7YB
8X2
9X2
Please help. Thanks.
Edited by SFAHank
Misspelling
AG1
AXK
AY0
AZ3
CJ2
C5Z
DL8
EF7
E63
FHO
G1K
H0U
IO6
I18
JD9
L83
MAH
MSL
MYC
NP5
NTB
QT0
RC4
RD4
RUF
UDD
UQ3
U2K
V8D
WMJ
X88
Z60
1LT
4AA
6YB
7YB
8X2
9X2
Should be a GT or GU code. Connect with GM customer service on the site here and request a build sheet.
Edited by JimCost2014
How exactly do I do that?
14 hours ago, Nasty said:
Look in your glove box. There should be a code that starts with Gu. You most likelyhave GU6 which is 342
that sticker does not exist in the glove box on the new ones.
I got my build sheet by sending a PM to the GM customer service account on this forum. You provide your VIN and they e-mail you the full build sheet. I don't know if they still respond. But somehow you can reach out directly to them, or ask your dealer for it.
My sheet has 99 codes on it, so you are only seeing less than half of them from the QR scanner. That sucks.
 2018 Axle Codes
G80
Differential, heavy-duty locking rear
GT4
Rear axle, 3.73 ratio
GU4
Rear axle, 3.08 ratio
GU5
Rear axle, 3.23 ratio
GU6
Rear axle, 3.42 ratio
15 minutes ago, Nasty said:
What yesr is truck? Both mine are 16s
the OP has a 2018. I always forget you guys who use the mobile site can't see the signatures.
I sent a message to customer service on this site several days ago and still haven’t heard back
  • 3 years later...
Reply to this topic...
