Discovered! Features you may not have known about...
14 minutes ago, Brummie99 said:
That works on my 2017. Press and hold the unlock button on the fob and all windows open. Unfortunately there is no way to close them all again other than manually. This has been discussed on here several times.
Wow ,  that's half baked.  I guess it's the same on the newer truck because he had a hard time trying to figure it out using common sense LOL but then again no such thing as common sense anymore
On 6/24/2018 at 8:31 AM, Rolling Thunder said:
Can someone describe how to "Untag" a singer for the radio?  I accidentally 'Tagged' a performer and every time she appears I get the notice.
Select menu in the radio screen then select tune select then I think manage to delete the artist or song
On 9/6/2018 at 5:43 AM, KJS Sullivan said:
I saw on a video on YouTube Somebody demonstrating the GMC Sierra 2019 and it showed him using the key fob to lower all the windows at once, but he had a very difficult time figuring out how to raise all the windows at once so there must be an all auto feature on the new trucks maybe on the higher end trim levels. Sad yes because my old 1998 Mercedes ghetto hooptie car has all auto down all auto up. It's a Sierra Denali but I use it a hundred percent for work
Sent from my SM-G955U using Tapatalk
I believe there is a button/lever center dash at the bottom that will raise and lower all the windows.
There might be something inside the cab however he was trying from the outside using a key fob he was able to lower the windows but not raise them. The truck appeared to be new to him only had 500 miles on it, so maybe he didn't know exactly what to do
I don't know what to tell you.  It's a 2018 Sierra SLT.  I hook up the boat trailer, put the transmission in drive, and after a few seconds parking assist turns itself off.  I get a message on the DIC and the light on the parking assist switch extinguishes.
Since I've seen this thread, I've been playing with the fob and the settings in the truck.  I've been able to make the windows go down using the fob.  I haven't been able to make the mirrors fold using the fob.
Fold the mirrors with the fob by holding the lock button down for about 5 seconds.  There maybe a setting to turn this feature on/off in the radio screen.  Also in the radio is a setting for rear park assist with or without towing.
Edited by Sir Dan
yes, you need to enable the mirrors in the settings
Eureka!  I have found it!
I found the setting in the truck that enables the mirrors to fold with the fob.  I also found a setting called “reverse mirror tilt”.  Put the transmission in reverse and the side mirror tilts down to give you a better view of the area to the rear of the truck.  It really doesn’t make much of a difference, especially with how I have the mirrors set up.  But its all cool.  I’ll continue to play with it.
  • Like 3
I have a 2016 CC All Terrain. Love having the volume and skip song buttons on the steering wheel. But how do I Pause/Play without using the Touch Screen? Surely there’s a way??
Just press the forward/back button on your steering wheel. Same ones that you use to skip songs. It'll start playing without needing to touch the screen. You can also hit the buttons on the dash and it'll start playing as well.
Sent from my SM-N950F using Tapatalk
