Hello guys,
i've a
2004 gmc topkick with allison 2000. Gear selector is not showing on dash, reverse goes in gear ok but all other gears have no power.
I changed neutral swicth , ignition switch and now  the tcm.  Fuses are all fine- Problem still persists and service light is not on and no codes.
Any suggestion?
Thanks,
Augusto
  • 1 month later...
Hello guys,
i've a
Any suggestion?
Thanks,
Augusto
Was TCM programmed ?
Data at IPC seeing PRNDL?
Pressure test done on tranny in fwd gear , ?
Access to service information and scanner ?
Are you a handy guy technically?
Oil condition of tranny ?
Debris in pan ?
Some questions for ya
