Windshield Chip Repair
diyer2
This has worked for me quite well.
Here in Colorado they spread fine gravel and a chemical on the roads in winter.
Causes lots of windshield chips from flying gravel.
As soon as you get a chip, try to do this ASAP to keep dirt out of the chip.
Clean windshield and chip with denatured alcohol.
Blow out chip with air. No moisture/water in air.
Fill chip with super glue.
Let set until super glue is hard, cured.
Spray repair with window cleaner like Windex.
This is used as a lubricant.
Take a new single edge razor blade and scrape of excess glue.
Always keep the glass wet with window cleaner while using razor blade.
I did this to some chips on the windshield of the wife's car 5 years ago.
It hasn't cracked or started growing in size.
