- 0
Spark plug for 2017 6.2L w/ supercharger
Similar Content
- 2 replies
- 276 views
- 3 replies
- 3,948 views
- 6 replies
- 8,362 views
2020 High Country 6.2L Whipple Supercharger Build 1 2 3 4
By AEmedic,
- Supercharger
- 6.2L
- (and 1 more)
- 53 replies
- 43,988 views
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 11 Members, 2 Anonymous, 1,806 Guests (See full list)
Question
Mileguru
Hello,
I have a 2017 Sierra SLT Crew Cab 6.2L with a Magnuson TVS1900 on it. The pulley and boost are stock from Magnuson, so probably 8psi max boost. I want/need to replace the spark plugs because I get a little bit of ping when really engaging the supercharger. The ping is very short and goes away, but it even does it with around a 94 octane (mixed 91 with 100). It is much, much better with the 94 octane, but it is still detectable.
My questions are:
1) Should I get a one or two step colder plug?
2) Should I lessen the gap to 0.028in or 0.03in?
3) Should I get projected or non-projected tips?
4) THE BIG QUESTION, do I need to get the exact same size plug as the stock ACDelco 41-114 (aka GM part number 12622441)? The REACH is what seems to be different.
I believe the stock plug specs are:
Heat range: 16
Gap size: 0.04in (1.02mm)
Reach: 0.98in (25mm) THIS IS WHERE THE NGK PLUGS DIFFER
Hex size: M16
Insulator height: 0.99in (25.3mm)
Seat: Tapered
The plugs I am considering are Brisk (which have the SAME reach) and NGK (which have a DIFFERENT reach). Eight of the Brisk plugs is way more expensive than NGK.
Brisk RR14YS - two steps colder, projected tip, 0.028in gap, same REACH as stock
Brisk RR14S - two steps colder, non-projected tip, 0.03in gap, same REACH as stock
Brisk RR15YS - one step colder, projected tip, 0.028in gap, same REACH as stock
Brisk RR15S - one step colder, non-projected tip, 0.028in gap, same REACH as stock
NGK BR7EF 3346 - two steps colder, non-projected tip, 0.28in gap, 0.709in (18mm) REACH which is different than stock
NGK BR6EF 3177 - same but one step colder
7 answers to this question
