Just checking on this mod.  I have an LT and just recently upgraded my DL8 mirrors to the DL3 with the DIY kit.  I have heated seats but not the adjustable pedal.   I want the heated/cooled seats and have found some for sale.  While I would make the time to do the conversion, I don't have the time or the wherewithal to figure it out myself.  In looking at your Dr. Harness website I don't see any mention of this project other than the seat memory bypass harness.  Do you have the directions and a DIY wiring kit for for this project?
I do not. I have completed this retrofit on 3 local trucks. In order to fully integrate seat memory, you have to use factory DL3 Harnesses, Factory DL3 Fold switch, factory door panel harnesses (both sides), swap passenger window switch for a DL3 Memory switch. You’ll also need to remove all DL8 wiring and install DL3 wiring in both door jamb connectors on the dash side. In addition, you have to install wiring from both door jambs to the driver seat memory module. Lastly, programming of the seat memory module and the cluster. It is VERY extensive and not a DIY harness that I can produce to sell.
  • Like 3
