Having trouble starting after fueling
New to group. Stumped and frustrated in Kentucky thanks for the add My 2006 Colorado doesn't want to start after getting gas whether i fill it up or put 20 in so i started putting gas in while left running but even with that if i put the gas in to fast it wants to stall out. Any one else have this problem and if so can you give me advise as what to do to fix it thank you in advance
  • 1 month later...
Yup, your purge valve is stuck open and every time you fill the tank you push fumes to the intake and flood it.
This is the issue most likely. Easy $10-ish fix.
