Mark Kennedy Posted February 21, 2018 Share Posted February 21, 2018 I've got a 2016 GMC Sierra 1500 with 16 inch wheels. {{Updated 17 inch wheels Thank you Leevon }} If I were to upgrade my truck to a 20 inch wheel or larger would the truck computer automatically compensate for the larger wheels? When it comes to the speedometer. Or would I have to have the speedometer fixed to give proper mile-per-hour. I don't want to guess how fast or slow I'm going? Thanks Link to comment Share on other sites More sharing options...
a_salazar08 Posted February 22, 2018 Share Posted February 22, 2018 1. There is no way for the computer to automatically know what size of tire you are running. The stock tires for a 1500 is usually about 31", so that's what it's programmed to. It calculates the speed by resolutions. You will need to buy a programmer to adjust it. (diablo, hyper tech, etc.) There are ones for speedo-only and others with more features. 2. Remember, it's about the diamter of the TIRE, not the WHEEL. If you got a new wheel tire package where the wheel is bigger but the tire is smaller (to maintain near-stock diameter), then you don't need to do anything. Link to comment Share on other sites More sharing options...
Donstar Posted February 22, 2018 Share Posted February 22, 2018 7 hours ago, Mark Kennedy said: I've got a 2016 GMC Sierra 1500 with 16 inch wheels. If I were to upgrade my truck to a 20 inch wheel or larger would the truck computer automatically compensate for the larger wheels? When it comes to the speedometer. Or would I have to have the speedometer fixed to give proper mile-per-hour. I don't want to guess how fast or slow I'm going? Thanks Check your current wheel size. The smallest stock wheel size is 17". Post your current tire size on a tire conversion website and you will find equivalent diameter tire sizes for larger rims. Or, post your current size here and we can help!. Link to comment Share on other sites More sharing options...
Leevon Posted February 22, 2018 Share Posted February 22, 2018 I upgraded from the factory 17's to 20's (275/55/20) tires and the speedometer is dead-on. I did update my VIN through GM software to account for the 20's so I wouldn't get any flack at the dealer for warranty. Keep in mind you can only update for factory tires sizes. Any larger tires aren't available with factory software. You'd need a custom calibration loaded from a tuner, or use a handheld tuner. Link to comment Share on other sites More sharing options...
